Is there an easy way to see the conntens of subpicture streams, without looking the whole movie. You know some movies need forced streams, because they sometimes use foreign language like in "last samurai" or in "man on fire" and when doning a backup without menu and unnecessayr subpictures, how do i know which stream i have to choose, e.g. using dvdshrink. I know the forced stream option in dvdshink, but i dont know which stream i have to use if there are, let's say 3 streams in my language. Any idea?
Hi-
One way to see the contents of each stream is to convert the DVD subs to IDX/SUB format. Open the IFO for the movie in VobSub Configure. It comes with the VobSub package. If you have GKnot installed, it's in the Subtitles Tab. Give it a destination folder, hit "OK" and wait a couple of minutes. When done, you'll have big IDX/Sub files containing all the sub streams. Then open them one at a time in Sub Resynch (also in the VobSub package, also in GKnot) and you'll see the timings and dialog for the various streams. The Forced Subs will be marked.
You have to remember that sometimes there are Forced Subs, and they'll be contained within the larger stream of all the subs for that language, and they'll be marked as Forced. Sometimes the subs for a different language will have their own separate much smaller stream and aren't Forced technically. I don't know which is the case for your 2 movies.
Assign default audio and default subpicture streams for movie only backups.
By mattstan in forum DVD RippingReplies: 12Last Post: 11th Sep 2012, 04:59 -
Easy prgram that converts HDTV TS streams to x264??
By peggypwr1 in forum Newbie / General discussionsReplies: 16Last Post: 4th Jun 2011, 04:02 -
simultaneous display of 2 subpicture streams?
By Radish in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2009, 02:31 -
OSX Program to Extract streams from .m2ts?
By marklight in forum Video ConversionReplies: 1Last Post: 11th Sep 2008, 23:27 -
Multiple subpicture streams in menu for different color schemes?
By Alex_ander in forum Authoring (DVD)Replies: 5Last Post: 12th Jul 2008, 02:53
