Not sure if this is the right forum. Does anybody know of a PCI card that can be used to receive OTA HDTV signal and send it to the a HDTV? I want the card to have a HDTV tuner as well as HDMI output?
Thanks in advance.
Ravi
MYHD130 with a duaghter card will get you dvi output from there i guess you cound use a adapter ohter than that i dont think theres a card with hdmi
This company has a fair selection of HDTV cards and accessories. I use a DVICO 5 card for OTA HDTV and a ATI 9550 AGP card out through a ATI to Component adapter to a projector.
http://www.copperbox.com/lite/htpc.php
There are also DVI to HDMI adapters: http://www.ramelectronics.net/html/DVI-hdmi_adapt.html#fmhdmi
Ram Electronics has all kinds of HDTV items. -
Yep I'm planning on getting the fusion 3 (cheaper than the fusion 5). I got a lot of help from the folks here on the ins and outs of hdtv. I'll dig up my thread and it should help you too
EDIT - Here it is:
https://www.videohelp.com/forum/viewtopic.php?t=285447
FYI a digital stream will take up about 9gb per hour.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
ATI HDTV Wonder PCI
By NautTboy in forum Capturing and VCRReplies: 3Last Post: 16th Mar 2010, 00:00 -
Diamond TV Wonder 650 Theater PCI-E TV Tuner Card ATSC NTSC HDTV FM with Rogers.
By Cabal2000 in forum DVB / IPTVReplies: 3Last Post: 25th Feb 2010, 20:18 -
Need al little help getting my new ati hdtv pci card to sense HDTV channels
By MidnightMike in forum ComputerReplies: 8Last Post: 23rd Jul 2008, 02:12 -
Good Firewire PCI card for Capturing HDTV?
By superdud1400 in forum Capturing and VCRReplies: 1Last Post: 12th Jun 2008, 05:11 -
Lines in picture, HDTV PCI Card
By dnbrvr in forum DVB / IPTVReplies: 1Last Post: 2nd Dec 2007, 09:58
