Results 1 to 15 of 15
  1. http://shortfilm.videohelp.com/
    Upload your entries soon !
    Awards announced 15th Jan.
  2. The clock is ticking!
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. Hopefully Baldrick will put the finalist on the site for us to view.
    Id like to see the members work.
  4. Member lumis's Avatar
    Jan 2005
    the remnants of pangea
    when i uploaded my entry (which i'm sure wont win), i didnt see many others on there.. how many entries have there been?
  5. Member dipstick's Avatar
    Jan 2005
    Dark side of the Moon
    At the moment, it looks like 8 entrys, unless there's more in another folder.
    What makes you so sure you won't win? You never can tell.
    I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix,
  6. I think it would be pretty hard to make a movie about the cat. BALDRICK. That is what you have to do right?
    Life is like a pothole, you just have to learn to get around it.
  7. Member dipstick's Avatar
    Jan 2005
    The movie can be about anything you want. Just leave some reference to Baldrick or whatever. It is pretty unlimited, wich leads well to creativity.
  8. Wish I had the time to be creative.
  9. Member dipstick's Avatar
    Jan 2005
    I hear ya. With a family, mortgage and a job with crazy hours, it's tuff to come up with the time to be creative. Really, the hardest part for me is coming up with the ideas. The actual production is easy in comparison.
    Sometimes it helps if I have a few drinks and get a good buzz on. Some of my best video productions were created after a few drinks.......go figure.
  10. I have not carefully watched all the entrants yet, but some are quite good.
    We will make them available for public viewing after all entrants have been finalised.
    Regards.
    Michael Tam
  11. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Can I assume you would let us know if there were some difficulty viewing our entries?
    (Edit: I'm curious because I've never used xvid before this project.)
    Buy My Books
  12. Member dipstick's Avatar
    Jan 2005
    I'm curious how badly BJ_M hosed my video when he converted from wmv to divix/xvid.
    But it's my fault for not using the required format...........oh well.
  13. Член BJ_M's Avatar
    Jul 2002
    Canada
    still looks the same - i dont see any difference ..
    before:
    after:
  14. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    C'mon BJ_M. You can do better than that. If your going to pull the gag, at least use 2 different filenames. (Properties shows it's the same picture.)
    Buy My Books
  15. Member dipstick's Avatar
    Jan 2005
    The funny thing is, in a weird way, those images do resemble my movies.
