Hi
Been having problems burning dual layer
A lot of the help answers coming back have advised to burn with recordnowmax sonic v7.3 - ok i've just bought it and installed it
but it appearsto be all automatic - cannot see any drive speeds to change or much of anything
or am I missing something
anyone with this software please advise
regards
Hi Got the name of the new program wrong its Sonic RecordNow Plus v7.3
Should have read as follows
A lot of the help answers coming back have advised to burn with Sonic RecordNow v7.3 - ok i've just bought it and installed it
But it appears to be all automatic - cannot see any drive speeds to change or much of anything . doessn't ask about layer change etc
regards
Who on earth advised you to purchase that software? I have been using Nero 6 and have not had a failed dual layer burn yet. (knock on Wood) Record now use to be owned by 'Vertis" and was bought by the folks at Sonic.
Originally Posted by jdizzy40
It is automatic but you still set the parameters for the operation. Open the program and click on the little wrench at the upper right, just below the CLOSE symbol. Go to the general settings and then to advanced right under that. There it gives you the writing speed for either CD or DVD. There are numerous other settings that you can apply. Good luck!
I believe there are two kinds of people in the world:
1. Those who ask, "Who on Earth advised you to [insert action here]?"
and
2. Those who don't. -
it also depends on what sonic recordmax version you have. For example I have their 29$ version, most options are greyed out or just not available at all (such as selecting the recording drive speed). It sounds more so from the original post that the one being used is the $20 something version.
Missing a codec?
By jnojr in forum Newbie / General discussionsReplies: 5Last Post: 2nd Dec 2008, 17:24 -
missing sound
By MONSTERTITO in forum Newbie / General discussionsReplies: 5Last Post: 30th Sep 2008, 23:39 -
favorites missing....
By ray316 in forum ComputerReplies: 3Last Post: 20th May 2008, 13:19 -
Missing link!
By DereX888 in forum FeedbackReplies: 17Last Post: 13th Sep 2007, 23:22 -
Missing files
By justinguitar in forum ffmpegX general discussionReplies: 5Last Post: 25th May 2007, 18:40
