I finished authoring a movie tmpgenc dvd author and went to use the dvd writer. When I start to burn I get an error message about an ordinal in pxdll.
Guest34343Guest
Get px.dll Version 1.8.34.500 from sonic solution and copy it into the program folder of TMPGEnc, or the location of your bad version. WinAmp and other apps install bad versions of this DLL.
I also saw this on the net:
I had the same problem. Here is what I did:
Uninstalled DVD Author
Uninstalled Nero Burning Rom (I don't think that really mattered, but did it anyway)
cd c:\windows\system32
del px*.*
I had to delete anything that started with px from the system32 directory under the windows directory.
(actually I created a temp directory to hold em just in case I needed em)
Then re-installed DVD Author.
worked like a charm after that
Write Error with Internal DVD Writer
By Soviani in forum DVD & Blu-ray RecordersReplies: 1Last Post: 9th Oct 2009, 01:50 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGEnc DVD Author Error - Video Bitrate too high
By powerkoala in forum Authoring (DVD)Replies: 9Last Post: 22nd Nov 2008, 12:16 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 18:20
