moved.
Results 1 to 10 of 10
Last I heard, there was no such thing as dvd dl -r
Google is your Friend -
My last six dual layer burns on my NEC 3550a disagree with that statement.Originally Posted by Krispy Kritter
Are you sure?
http://www.necsam.com/optical/products/ND3500A/specs.cfmGoogle is your Friend -
umm . . . I never owned or even installed one of those for someone else. I said an NEC 3550a. Yes, I'm quite sure.Originally Posted by Krispy Kritter
What was the OP's Question?
They're both available (but DL+R moreso). They both work. They both have problems in some players? They both are a whole hell of a lot slower than their SL counterparts.
Cost? Look around in your area and do a Google search...
Scott -
I've noticed that if a particular player has a problem with DVD-r DL it also has problems with DVD+r DL and vice versa. Oddly enough it seems to be the more expensive models which stutter on these discs or refuse to play them.
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 18:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 13:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 09:59
