Hello I just bought a LG 4167 DVd writer. The disc I am using are TDK 8X DVD-Rs form Costco. The media code is TTG02 I believe. I have updated the LG drive to the lastest firmware. When I try to write at 8x I get error messages whether I am using dvd decrypter or roxio, but at 4x, eveything burns fine. What am I doing wrong? Thanks.
All media will not burn at the same speed with the same results on every burner. All burners are slightly different due to chipsets and firmware, and media varies from batch to batch, and brand to brand. A media that I could burn at 16x, might only burn at 8x on your burner, or visa versa. It could just be a bad batch of media. TDK can vary greatly. You need to do a CDSPEED disc quality scan of the dvd, and post the results here. Or, try a good "made in japan" media.
Rob -
Read this review and see which discs worked well with your unit.
http://www.cdfreaks.com/article/242 -
harley2ride is correct. I used to own a Sony DRU-500A which is a 4X burner. I could never get to burn Ritek 4X discs to burn at 4X with any software. It would only burn at 2X max, even with the latest firmware. Other discs such as TDK burned fine at 4X.
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 18:55 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
