Hi,
I use TMPGEnc to make my mpgs for DVD. I have been trying to use GUI for dvdauthor, but it gives an error. Does it have anything to do with multicomplexing or whatever.
Does TMPGEnc multicomplexed videos?
By the way, what does it mean?
although i have never used GUI for dvdauthor, it appears that it does not accept elementary audio in wav format. TMPGEnc can output your mpeg2 as "program" stream (muxed audio and video) or "elementary" audio and video streams (separate streams). in the "elementary" stream mode,you can choose to have the audio output as mp2 or as wav. you should choose the elementary stream mode with your output selected as m2v+mp2 separate streams. GUI for dvdauthor should accept those.
I said I'll be done in a minute. I meant a Microsoft minute. -
Exactly!
One more point: Make sure the mp2 audio stream has 48 kHz sampling rate (use a DVD template in tmpgenc).
BTW It is possible to use lpcm ('wav') audio with GfD, but it has to be in motorola byte order (big endian) and without a riff/wave header. Therefore it is not directly supported. In order to use it, you need to 'premultiplex' your elementary streams with the commandline mplex and that's nothing for beginners...GUI for dvdauthor:
https://www.videohelp.com/~gfd/
Multiplexing Multiplex files?
By mrjust in forum Newbie / General discussionsReplies: 5Last Post: 3rd Dec 2012, 23:54 -
Basic question on MPEG-2 multiplexing
By nharikrishna in forum Authoring (DVD)Replies: 7Last Post: 2nd Feb 2011, 22:32 -
Multiplexing Issues (mp4muxer 0.9.3)
By JuddM in forum Video ConversionReplies: 4Last Post: 19th Jan 2011, 05:00 -
VOB multiplexing
By atulbha in forum Authoring (DVD)Replies: 8Last Post: 24th Jul 2009, 15:52 -
DOS multiplexing for DivX and/or other MPG?
By Figge in forum Video ConversionReplies: 2Last Post: 25th Mar 2009, 02:55
