Ok, yes I already saw the sticky up there with the DVD Remake tutorial. But that's not what I wanna do... Here's the problem. A movie is split over two DVDs (annoying) I want to get the video from the second DVD and join it with the first and keep the FIRST dvds menus as well as the second dvd's chapter stops.
Get what I'm saying? Is that possible without breaking my back or should I just shut up and do the dvdremake way? :P Thanks!
Have you seen this DvdReMake Pro guide? http://www.dimadsoft.com/dvdremakepro/ht_merge1.php
http://www.dimadsoft.com - home of DvdReMake and MenuEdit tools
Longevity of Standard DVDs and BluRay DVDs
By bmccollum in forum MediaReplies: 10Last Post: 20th Oct 2010, 19:32 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 02:02 -
Newbie's DVD burner isn't recognizing DVDs as burnable (Both DVD+/-R)
By OhGodHelpMe in forum Newbie / General discussionsReplies: 9Last Post: 30th May 2007, 09:48 -
I want software that copies DVDs and transfers torrents to playable DVDs!
By maccaneer in forum MacReplies: 14Last Post: 28th May 2007, 10:02
