Hello room im new here and im tryn to find the best , easyest way to convert Avi,mpeg to DVD ?
Results 1 to 9 of 9
Hi grimee1,
Because of the numerous tools and methods available to do this, there is no "best" and easiest - the two are usually mutually exclusive, and one person's opinion will differ from another.
There's generally two categories:
1) "All-in-one" tools - Quicker and easier, but common opinion is that you get less control over what's going on and so may end up with less quality.
See the "All-In-One DVD Converters" in the "Tools" section.
2) Use dedicated tools for each step of the process (capture, edit, encode and author) - longer and more to learn, but more control and (once mastered) you should get excellent results from excellent quality source material (e.g. DV AVI).
See the "Video Encoders (MPG/DVD)" in the "Tools" section.
Of course, GIGO still applies...
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks for the reply and help i will look at the all in one.. for more help. But let me ask this question if there was a all in one which one would u use. Quality not all that important its just for me at home.
Again thanx... -
No problem.Originally Posted by grimee1
I fall squarely in the group that goes for my option 2 (above) - I've never used any all-in-one, so I can't comment. redwudz has been around for a good while, so I'd trust his (her? Sorry, dunno
) judgement.
Carpe diem.
I'm a him, he
I would still recommend you learn the long way as daamon mentions, even if you try 'the quick and easy' way. You will find some videos that DivxToDVD can't handle.
This is a hobby to most of us and tinkering with the encoding options and getting the best quality out of a conversion is very satisfying. It takes a little reading and experimenting, but I have always found it worthwhile.
I'll agree with him (Originally Posted by redwudz
) and second that - if you're that way inclined, it is pretty satisfying getting a decent result.
Carpe diem.
winavi spam deleted
You are in breach of the forum rules and are being issued with ban
/ Moderator offline -
How much are they paying you to say that ???Originally Posted by DaisyLin
After all, WinAvi is the biggest piece of monkey crap ever
If in doubt, Google it.
Mpeg vs. Avi for VHS to DVD
By smartel in forum Newbie / General discussionsReplies: 4Last Post: 1st Jan 2011, 11:39 -
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
dvd to avi or mpeg
By AeR0 in forum Video ConversionReplies: 3Last Post: 22nd Jan 2010, 13:45 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
DVD to MPEG-2/AVI
By Nitro89 in forum DVD RippingReplies: 21Last Post: 14th Apr 2008, 15:17
