I can not capture the video from VCR with VirtualDub, I follow the instruction "How to" "Capture", but getting following error
"VirtualDub Capture error
Error 424:error:Canot open the video input device"
Can any body help me
Results 1 to 9 of 9
Give us more details about what you attempt to do (parameters), and also about your system (hardware, OS).
This message can come up when your capturing device cannot capture at the desired resolution, for example...
BeTa -
Sounds to me like your capture card driver isn't properly installed. This is not a Virtualdub problem.
I got it to work after changing the resolution to lower, it was on full screen. I am not able to see SVCD resolution in VirtualDub program. I would like to capture the avi in SVCD format but there is no SVCD resoultion, may be is because of my capture card(Pinnacle PCTV) or is it some thing I am doing wrong. I am following the instruction in "How to capture" section
did you turn on overlay when capturing? if so try preview (under video) instead.
ben.
I am using PCI PCTV, also (NTSC). I can capture up to 640x480.
I capture @480x480 for my home videos (Hi8), and @352x480 for recording from VHS.
My system is PIII, 800MHz.
Make sure that you force preview instead of overlay, and you may want to hide view during capture.
BeTa
<font size=-1>[ This Message was edited by: BeTa on 2001-07-18 09:00:36 ]</font> -
Since I am not familiar with VirualDub and first time using it can you guys let me know what to do exactly. I try to follow everything in "How To convert section" but did not get option for SVCD resolution or even good VCD option. All I see is 320 x 240 option and there was anothe option 640...something full which would not let me capture and gave me error.
Thank in advance -
When I use Virtualdub I set it at 640 x 480 in the format option then force it to 480 x 480 in the user defind option. Right now I find the PIC codec to be the best compression. I set the frame rate at 29.970 for my purpose but lower it to 23.976 if I get a lot of frames being dropped. I also set the sound to CD quality, caputre to a different drive than the system drive and set it to preview mode.
<font size=-1>[ This Message was edited by: Freddie100 on 2001-07-18 15:15:44 ]</font> -
I am able to do one thing now after going to video and preview instead of overlay. How I can force to get 480x480 resolution. Where I exactly go to make changes. When I type in the field and say ok it would not work.
Thank you
VirtualDub Error
By WebMaximus in forum Video ConversionReplies: 5Last Post: 6th Jun 2011, 13:29 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
Virtualdub Error
By Hittz in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2008, 08:27 -
VirtualDub error
By Smallan in forum Video ConversionReplies: 2Last Post: 3rd Jun 2007, 00:34
