I'm authoring dvds using this guide, but no matter what I do I can't make my WinDVD7 or any other similar dvd player show the last subtitles I imported to my dvd-lab Pro project.
Maybe someone had some problems of this kind and know the solution? Any help would be highly appreciated![]()
Well, I have same problem just one differance. I can't get to display the First subtitle. I have three subtitles. PowerDVD & Apex DVD both displays only 2nd and 3rd subtitle but for the 1st it stays blank like no subtitles. But both says there are three sub titles. The two subtitles are displayed are same except the font size while the first one (the one I can't get to dispplay) is very short subtitle (in terms of number of subtitle entries). Basically I want my DV time code as subtitle so I created two SRT file using Subtitle Workshop one Displays Date & Time in HH:MM format and other has Date and time in HH:MM:SS format. The movie is 26 minute long so the one that has HH:MM time code has only 34 entries and while the HH:MM:SS has 1600+ entries.
Does any one know why? -
Media Player Classic shows that there are 4 subtitles but when I try to select ones that are not displayed by WinDVD it just jumps to the first subs
[DVD Lab Pro] subtitles wrong time
By dom61 in forum Authoring (DVD)Replies: 2Last Post: 4th Sep 2011, 07:42 -
DVD-Lab Pro Subtitles Encoding troubles
By laste in forum Authoring (DVD)Replies: 1Last Post: 16th Jan 2011, 14:12 -
DVD-Lab Pro: Subtitles change text
By TheLaserdisc in forum Authoring (DVD)Replies: 8Last Post: 18th Aug 2010, 12:23 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 15:14 -
out of sync subtitles - DVD Lab Pro
By GangstaRap in forum Authoring (DVD)Replies: 2Last Post: 12th May 2007, 15:57
