I'm ripping the video from a DVD. I ripped it using MactheRipper to get the VIDEO_TS. Then I'm using DVDxDV to create a QT movie that I can do some color correction and other filters in FC Pro. That's great. I've got that under control.
However, the original disc is extremely complex. You can play the whole video, portions of the video with subtitles (captions for trivia), and portions of the video without subtitles. I believe that this is all done with scripting so that depending on which option you select, it will only play certain chapters of the stream (a story, if you're familiar with DVD Studio Pro).
Is there a utility that will rip a file containing the chapter information? Even if it's just a text file with the timestamps in it, I'll take it. What about ripping subtitles? What about ripping a story..even if it's just a list of chapters that play for each option?
It's pretty complex. But I'd appreciate any help.
ouch.
your basically asking to de-author the disc,
and break it back down into all its components.
I'm thinking along the lines of something
Ti (sp) Forester would create....he's big into
creating stuff that will allow you to edit the DVD
AFTER the fact of creation.
You might try his website...."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Yeah, it's a toughy. Thanks for the suggestion. Do you have Ti Forester's link?
Take a look at Miraizon's Cinematize. They also are good at responding to email questions.
dvd ripping stops
By jbd441 in forum DVD RippingReplies: 1Last Post: 12th Mar 2012, 20:19 -
Ripping One File Per Chapter
By neumannu47 in forum DVD RippingReplies: 4Last Post: 3rd Feb 2010, 07:47 -
MKV chapter ripping
By animalia in forum EditingReplies: 2Last Post: 5th Aug 2009, 21:53 -
How do I remove chapter stops?
By Ronny G in forum Authoring (DVD)Replies: 5Last Post: 9th Apr 2009, 08:42 -
Video stops after intro - is it a chapter-problem or just corrupted?
By offtherecord in forum Software PlayingReplies: 2Last Post: 21st Nov 2007, 10:38
