Hey guys,
I just started transferring several miniDV tapes via the firewire connection to my Canon Optura 20 and things were going just fine. The issue I have is that I haven't figured out how to get the darn AVI file that is generated to be named what I want it to... something other than "Tape1.avi" or whatever. During the capture process, the clips generated and resultant AVI files are being saved to my RippedVideo directory. When I name a particular collection, it doesn't name the AVI file the same name... it just keeps it as "Tape1.avi". To work around this, I just used Explorer and renamed the AVI file to the name I wanted.... but this caused all of the Clips in that collection to become invalid now that the source path was no longer C:\RippedVideo\Tape1.avi.
So the short question is... how the heck can I specify a name for the captured AVI file BEFORE I record to disk from the camcorder. If this isn't possible, how can I rename the AVI file after the capture process and have it reflected in the details in a given Collection in WMM?
Thanks,
Jeff
Ugh... turned out to be a real dumb thing that I missed. Evidently at some point I had checked to "auto generate" the output files. Once I unchecked that, as soon as the capture finishes, a dialgue box appears so you can name the file as you see fit.
Jeff = goober.
Thanks,
Jeff
Bad Vhs transfer in digital as source
By mammo1789 in forum RestorationReplies: 15Last Post: 4th Nov 2011, 22:04 -
Newbie - Question regarding VOB to DVD transfer?
By Greggles in forum Newbie / General discussionsReplies: 5Last Post: 19th Oct 2010, 16:37 -
Unable to transfer a videofile from a digital camera to my PC
By alegator in forum Newbie / General discussionsReplies: 7Last Post: 28th Dec 2009, 13:01 -
just got my first vidcam; a Panasonic HDC HS9 and after info on MPEG2 TS
By topcatstudios in forum Newbie / General discussionsReplies: 1Last Post: 7th Jun 2009, 23:08 -
Trying to transfer Digital 8 to DVD
By Johnny Kilo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 20th Aug 2008, 14:58
