I experimented with the cutting of a MPEG 1 -VCD ready movie.
i used TMPGE and it did the job fine although it took about 45 mins for the whole process.
I also used a freebie d/l called File Split(where you simply enter the Mb you want to split in 2.
It also worked no problem and took about 5 mins.
My question is,is there any reason why I can't use the "hack,and divide" method or is TMPGE the way to go.
Was I just lucky that it worked?
I Havent used Filesplit. The 2 that I exclusively use r Tmpge & Virtual Dub,Did file split actually give you 2 working halves?If so,I guess you found a good ,fast program(Filesplit)
I prefer to split on the 100th of a second by choosing the exact frame to split. Funny enough after having done about 100 movies I noticed there's mostly always a natural break on near the exact middle of the movie.
Problems Cutting MPEG video in VIRTUALDUB
By Rudyard in forum EditingReplies: 2Last Post: 30th Sep 2010, 21:25 -
New experimental TS cutting software for MPEG-2 and H.264 Transport Streams
By Nukster in forum EditingReplies: 2Last Post: 14th May 2009, 09:16 -
cutting an MPEG
By php111 in forum EditingReplies: 3Last Post: 7th Jan 2008, 08:32 -
Convert mpeg-2 to xvid while cutting commercials...
By swishbish33 in forum Video ConversionReplies: 5Last Post: 25th Oct 2007, 18:10 -
cutting with mpeg video wizard but making my movie longer :S
By chocolate_brownie in forum EditingReplies: 5Last Post: 18th Aug 2007, 21:45
