I tried to reencode this certain MKV file I have using mkvextractgui. To my surprise, the video stream is encoded in MP4 according to the program. Is there any other way to rip the video out (I already ripped the other streams without problems) since mkvextractgui doesn't seem to support MP4, and Vdub Mod can't also handle the video stream too.....
Results 1 to 21 of 21
You mean native MPEG-4 part 2 (V_MPEG4/ISO/ASP)? Don't think mkvextract currently supports it. Perhaps mencoder can demux? Err scrap that it doesn't even seem to support native mp4.
Ahhhh, no problem then. mkvextract can extract native AVC fine. Will give you a raw (*.264) stream which you can then remux to mp4 via mp4box or mp4creator. That is assuming that you want an mp4.
Funny, my mkvextract tells me it can't extract that stream.
Lemme check again.... maybe my mkvextract's an old version.
What'll I do if I want the stream to be in avi? -
Why would you want an avi? What plays an AVC avi that can't play an AVC mkv? Well ok you can leave out installing an mkv splitter for say wmp, but you still need to install an AVC decoder so it doesn't really make that much difference.
That said, if you really, really want an avi you can use avc2avi to remux the raw stream to an avi. -
I want it to be in AVI because my final product would be a VCD-compliant MPEG....
Unless there's an easier workaround.... -
That would be like saying I wanted a new car so I bought a motorbike. If you want a VCD convert to VCD compliant MPEG-1.
Wait, wait. Let me clear it up.
I have an mkv and I wanted it to be in VCD compliant MPEG1. I have successfully ripped all other streams except the video, which is in AVC format. And the only way I have been successfully made my MKVs into VCDs was by making the video stream into an AVI.
So uhh there ^_^ -
But how?
The only way I know of converting MKV was by going thru mkvextract or Virtualdub mod... both of which requires the video stream to be changed to AVI... -
So I guess there's no way around it as of yet...
I guess I'll wait for somebody to figure this out...
Thanks for the lots of info ^_^ -
Like I said, just convert directly to mpg. No need to open in VirtualDubMod or convert to avi.
OK wait. I found another file, this time an MP4 file with H624 video stream and AAC audio. How can I convert it to VCD-compliant MPEG1?
VLC uses built in decoders/splitters if you want to use them then you need to use it for encoding.
Yes you need an encoder installed. It works fine here with ffdshow, you need to limit the output to RGB24 first though.
Really though if you don't have a video decoder, etc. installed then TMPGEnc should simply refuse to open the source. -
Finally managed to MPEG1 the file!!!! Turns out I had to restart the unit first before actually doing anything.
Thanks so much for the help!!!!!
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 01:43 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Convert a .MKV file to mp4
By siopilos in forum Video ConversionReplies: 2Last Post: 22nd Dec 2011, 03:42 -
Optimal File Size BD-> MKV/MP4.
By nirbhayn in forum Blu-ray RippingReplies: 5Last Post: 24th Aug 2011, 07:31 -
How do you convert HD 720p MKV file to MP4 HD file without losing quality?
By SoccerLover in forum Video ConversionReplies: 18Last Post: 4th Nov 2010, 08:30
