  1. I've been happily using vcdimager for the last few months with different xml source depending on how much disc space i have.
    My simplest is a single menu displaying the film title which pressing play,next of 1 causes the film to play. Pressing the next and previous keys gives entrypoint skipping.
    Great - until this week when i successfully managed a 2 hr film onto one disc!
    The menu loads - but the key presses don't do anything.
    If I change the first playlist to sequence-01 it works, if i have the first playlist as an entrypoint(ie 0000) then it doesn't, although it did in the past.
    Also I cannot use timesearch on my dvd player.
    The curious thing about this is my source was originally ripped from an I-Author produced disc. This allows timesearch.
    Anyway below is my bog standard xml. FYI i don't use selection on each chapter because my alba dvd flashes "SELECT" up on my menus - which wouldn't be too good during the film.
    Anyway i have gone back to vcdimager classic because i can time search to 99 mins, then the clock resets to 00:00.
    ALL vcdimagers give a warning about the 100 mins btw - so i think it's a svcd spec that 99mins is the max.
    Anyway - any ideas, anyone?
    -----source follows ----
    <?xml version="1.0"?>
    <!DOCTYPE videocd PUBLIC "-//GNU//DTD VideoCD//EN" "http://www.gnu.org/software/vcdimager/videocd.dtd">
    <videocd xmlns="http://www.gnu.org/software/vcdimager/1.0/" class="svcd" version="1.0">
    <info>
    <album-id>SVCD</album-id>
    <volume-count>1</volume-count>
    <volume-number>1</volume-number>
    <restriction>0</restriction>
    </info>
    <pvd>
    <volume-id>MERMAID_2</volume-id>
    <system-id>CD-RTOS CD-BRIDGE</system-id>
    <application-id>IAUTHOR</application-id>
    <preparer-id>GNU VCDIMAGER 0.7.8 CYGWIN/I686</preparer-id>
    <publisher-id></publisher-id>
    </pvd>
    <filesystem>
    <folder>
    <name>VMP</name>
    <folder>
    <name>SVCDJ</name>
    </folder>
    </folder>
    <folder>
    <name>DATA</name>
    <folder>
    <name>SVCDDATA</name>
    </folder>
    </folder>
    <folder>
    <name>AUTORUN</name>
    </folder>
    <file src="_back.jpg">
    <name>BACK.JPG</name>
    </file>
    <file src="_front.jpg">
    <name>FRONT.JPG</name>
    </file>
    </filesystem>
    <segment-items>
    <segment-item src="blank.mpg" id="blank"/>
    <segment-item src="main_menu.mpg" id="main_menu"/>
    <segment-item src="chapters.mpg" id="chapters"/>
    </segment-items>
    <sequence-items>
    <sequence-item src="avseq01.mpg" id="sequence-00">
    <entry id="entry-001">514.160000</entry>
    <entry id="entry-002">894.160000</entry>
    <entry id="entry-003">1303.160000</entry>
    <entry id="entry-004">1632.160000</entry>
    </sequence-item>
    </sequence-items>
    <pbc>
    <playlist id="playlist-01">
    <next ref="selection-01"/>
    <wait>0</wait>
    <autowait>0</autowait>
    <play-item ref="blank"/>
    </playlist>
    <selection id="selection-01">
    <bsn>1</bsn>
    <prev ref="playlist-01" x1="0" y1="0" x2="0" y2="0"/>
    <next ref="selection-02" x1="0" y1="0" x2="0" y2="0"/>
    <return ref="selection-01" x1="0" y1="0" x2="0" y2="0"/>
    <default ref="selection-01" x1="0" y1="0" x2="0" y2="0"/>
    <timeout ref="selection-01"/>
    <wait>-1</wait>
    <loop jump-timing="immediate">1</loop>
    <play-item ref="main_menu"/>
    <select ref="playlist-02" x1="0" y1="0" x2="0" y2="0"/>
    <select ref="selection-02" x1="0" y1="0" x2="0" y2="0"/>
    </selection>
    <selection id="selection-02">
    <bsn>1</bsn>
    <prev ref="selection-01" x1="0" y1="0" x2="0" y2="0"/>
    <return ref="selection-02" x1="0" y1="0" x2="0" y2="0"/>
    <default ref="selection-02" x1="0" y1="0" x2="0" y2="0"/>
    <timeout ref="selection-02"/>
    <wait>-1</wait>
    <play-item ref="chapters"/>
    <select ref="playlist-03" x1="0" y1="0" x2="0" y2="0"/>
    <select ref="playlist-04" x1="0" y1="0" x2="0" y2="0"/>
    <select ref="playlist-05" x1="0" y1="0" x2="0" y2="0"/>
    <select ref="playlist-06" x1="0" y1="0" x2="0" y2="0"/>
    <select ref="selection-01" x1="0" y1="0" x2="0" y2="0"/>
    </selection>
    <playlist id="playlist-02">
    <prev ref="playlist-02"/>
    <next ref="playlist-03"/>
    <return ref="selection-01"/>
    <wait>-1</wait>
    <play-item ref="sequence-00"/>
    </playlist>
    <playlist id="playlist-03">
    <next ref="playlist-04"/>
    <wait>-1</wait>
    <play-item ref="entry-001"/>
    </playlist>
    <playlist id="playlist-04">
    <prev ref="playlist-03"/>
    <next ref="playlist-05"/>
    <wait>-1</wait>
    <play-item ref="entry-002"/>
    </playlist>
    <playlist id="playlist-05">
    <prev ref="playlist-04"/>
    <next ref="playlist-06"/>
    <wait>-1</wait>
    <play-item ref="entry-003"/>
    </playlist>
    <playlist id="playlist-06">
    <prev ref="playlist-05"/>
    <wait>-1</wait>
    <play-item ref="entry-004"/>
    </playlist>
    </pbc>
    </videocd>
  2. forgot to mention - the film plays to the end - just the entrys limitted to 99mins
  3. Firstly, unless I read it incorrectly, your entrypoints in the posted XML goes nowhere even close to 100 min??
    Note too sure on the 100 limit thing with SVCD specs though. I would have thought that as long as the sector addresses are < 80 minutes (if you burn with CDRDAO, you don't even have to worry about this) it should be OK. There may be a further limit with SVCDs though.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  4. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    Regards.
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Sorry - i posted the wrong xml. The real one is below - it's a stripped down version of the last - the only real difference is the entrypoint settings...
    I actually set the last entry as 99 minutes hoping this might cure it. It didn't. /I think/ if i set <play-item ref="entry-001"/> to "sequence-00" this might be an answer.
    I think the 99 min is possible an official svcd spec - stupid one. What i can't understand is why the selections have always worked before - and have stopped just because the sequence is >99 mins.
    Cheers for the feedback
    Dave
    <info>
    </info>
    <pvd>
    <volume-id>PLANET_OF_THE_APES</volume-id>
    <application-id>VCDIMAGER_AVISYNTH_VIRTUAL_DUB_TMPEG</application-id>
    <publisher-id>DAVEA</publisher-id>
    </pvd>
    <filesystem>
    <folder>
    <name>VMP</name>
    <folder>
    <name>SVCDJ</name>
    </folder>
    </folder>
    <folder>
    <name>DATA</name>
    <folder>
    </folder>
    </folder>
    <folder>
    </folder>
    <folder>
    <name>COVERS</name>
    <file src="d:\ape\back.jpg">
    </file>
    <file src="d:\ape\front.jpg">
    </file>
    </folder>
    </filesystem>
    <segment-items>
    <segment-item src="d:\ape\menu.mpg" id="main_menu"/>
    </segment-items>
    <sequence-items>
    <sequence-item src="d:\film.mpg" id="sequence-00">
    <entry id="entry-001">000</entry>
    <entry id="entry-002">600</entry>
    <entry id="entry-003">1200</entry>
    <entry id="entry-004">1800</entry>
    <entry id="entry-005">2400</entry>
    <entry id="entry-006">3000</entry>
    <entry id="entry-007">3600</entry>
    <entry id="entry-008">4200</entry>
    <entry id="entry-009">4800</entry>
    <entry id="entry-010">5200</entry>
    <entry id="entry-011">5940</entry>
    </sequence-item>
    </sequence-items>
    <pbc>
    <bsn>1</bsn>
    <prev ref="selection-01" />
    <next ref="playlist-01" />
    <return ref="selection-01" />
    <default ref="playlist-01" />
    <wait>-1</wait>
    <loop jump-timing="immediate">0</loop>
    <select ref="playlist-01"/>
    </selection>
    <prev ref="playlist-01"/>
    <next ref="playlist-02"/>
    <return ref="playlist-01"/>
    <wait>0</wait>
    </playlist>
    <wait>0</wait>
    </playlist>
    <wait>0</wait>
    </playlist>
    <wait>0</wait>
    </playlist>
    <wait>0</wait>
    <play-item ref="entry-005"/>
    </playlist>
    <next ref="playlist-07"/>
    <wait>0</wait>
    <play-item ref="entry-006"/>
    </playlist>
    <playlist id="playlist-07">
    <prev ref="playlist-06"/>
    <next ref="playlist-08"/>
    <wait>0</wait>
    <play-item ref="entry-007"/>
    </playlist>
    <playlist id="playlist-08">
    <prev ref="playlist-07"/>
    <next ref="playlist-09"/>
    <wait>0</wait>
    <play-item ref="entry-008"/>
    </playlist>
    <playlist id="playlist-09">
    <prev ref="playlist-08"/>
    <next ref="playlist-10"/>
    <wait>0</wait>
    <play-item ref="entry-009"/>
    </playlist>
    <playlist id="playlist-10">
    <prev ref="playlist-09"/>
    <next ref="playlist-11"/>
    <wait>0</wait>
    <play-item ref="entry-010"/>
    </playlist>
    <playlist id="playlist-11">
    <prev ref="playlist-10"/>
    <wait>0</wait>
    <play-item ref="entry-011"/>
    </playlist>
    </pbc>
    </videocd>
