Ok, i usually use vso divxtodvd as its very fast.
Is there any other software that offers a little bit better quality as i am looking for that step up.
I copy alot of DVD's from formats such as svcd(bin.cue) divx xvid, avi, mpg etc. Is there anything you lot recommend?
TMPGEnc encoder, or others and a authoring program like TMPGEnc DVD Author. The individual programs will give you better control and quality than any of the all-in-ones.
Would you reccomend changing then or is there not much difference or worth in the time over value of qual
Your method is fine, as far as I can see. The 'average' Xvid or Divx from the net is often not great of quality, so DivxToDVD may be a good choice for conversion to DVD.
If you had a very good quality Divx or Xvid, then you will likely get better quality with the individual programs. But it's a lot more work and a steeper learning curve.
Why not take a 5 minute clip from one of your Xvid files and try using a program like TMPGEnc to encode it? You don't have to worry about the audio for the test, just encode the video. Try a few different settings. That's really the best way to see if you can improve the quality. -
There are two improvements that can be made using the longer, manual method. The biggest problem with all Xvid/Divx etc conversions is the softness that comes from resizing up, and the enhancement of the inherent compression artifacts. Using the correct filters in avisynth or virtualdub it is possible to reduce the appearance of these artifacts, and sharpen the image. The trade-off is that this process is usually 3 - 4 longer than using something like DivxtoDVD. It is up to you whether or not the effort is worth the time. Sometimes I just let DivxtoDVD do it's thing - my kids do care if the image is a little soft. But other times it is worth the extra effort as a little careful sharpening can make a great difference.
Read my blog here.
Best conversions for dvd
By atvmxr in forum Video ConversionReplies: 5Last Post: 22nd Apr 2008, 10:47 -
DivX conversions to DVD
By catricric in forum Newbie / General discussionsReplies: 3Last Post: 3rd Apr 2008, 08:21 -
DVD to AVI Conversions Shutting Down System
By RolePlayArtist in forum Newbie / General discussionsReplies: 2Last Post: 1st Jan 2008, 13:35 -
clear, watchable flash to DVD conversions on the horizon?
By snafubaby in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2007, 10:06 -
Anyone get Super MPEG2 conversions to be DVD compliant?
By Rudyard in forum Video ConversionReplies: 7Last Post: 1st Jul 2007, 19:08
