it all works ok but when i go to create it on a disc my easy creator 5.0 says it wont work in a dvd player anyone know why, (im using tmpenc)
well I have a few questions, what plays all fine, your svcd ? what does it play fine on are you using a dvdplayer software or like win media player, but my most importrant question is what did ya cut the file as when your splitting the file be sure to split it as super video cd not mpeg1, I have done that on a few occassions, which really suxs when you dont realize it till after the fact, but make sure when splitting it its split as the correct file type, just a geuss with the lil information you did give out, but I dont beleive it says it wont play in a dvd player, but that to burn as an svcd it isnt compatable, dont remember I use nero
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
SVCD 2 DVD Not Working - Cant Add VTS or Click Convert
By rytech in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Feb 2010, 04:55 -
Can't convert avi to vcd, svcd etc...Failed Message
By shankbone in forum ffmpegX general discussionReplies: 2Last Post: 10th Oct 2009, 02:12 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
