i`ve read almoste every thread bout sound problems but nothing solved my problem
i`ve created an mpeg file with ulead moviestudio 9.
it doesn`t offer much as menu created is conserned so i though about trying dvd lab pro
first i`ve split the file to video and audio as many has writen here and then i imported it to dvdlab
i also transcoded the sound file to ac3
the video file is m2v 720X576 25fps pal
when i finished doing the menus and everythnig i compiled to dvd and then burned it to a philips dvd-rw using nero and the internal dvd write module
in both cases the dvd is without sound when played on a stand alone dvd.
i`m complitely lost....(and frustrated)
any suggestions???
thanks
Did you encode to dual channel stereo?
On your dvd player check left only and right only speaker settings. -
checking what Shadowmistress proposed i saw that the left channel is empty
if you add small brother who messes arround with the cables ...
the right channel cable was misplaced so the only sound source to the tv was the empty left channel...
i`ve spent the last two days for this ... i feel prety stupid...
thanks for your help everyone
AVI2ISO sound problem
By Belfour in forum Authoring (DVD)Replies: 3Last Post: 4th Aug 2008, 13:37 -
no sound problem
By bountylord in forum Video ConversionReplies: 3Last Post: 26th Apr 2008, 18:37 -
problem with my HP sound
By arabian in forum ComputerReplies: 2Last Post: 27th Dec 2007, 03:51 -
Sound problem on PC
By greenpop in forum ComputerReplies: 2Last Post: 18th Oct 2007, 06:36 -
Problem with sound
By jarko in forum Newbie / General discussionsReplies: 6Last Post: 11th Aug 2007, 20:22
