  1. Hi guys i have a downloaded file which looks exactly the same as a file that has been split into many rar files.
    The problem is that the filenames are different and wont extract with winrar. An example of one of these files is
    xpdvd-xxx(filename)xxxx-ntsc-dvdr-001
    I have never come across this one before, any help would be greatly apprecited.
  2. Originally Posted by trigger39
    Edit...forgot to add when you right click, you do not geet the option to extract, and all the files are 47.5mb in size
  3. What is the extension?
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    ACE files are sometimes numbered. Example abc.ace, abc.001, abc.002, etc.
    Google is your Friend
  5. Mod Neophyte redwudz's Avatar
    USA
    I've also seen .rar files numbered that way. You might make a copy of one and rename the extension to .rar and see what happens. Safer than working with the originals.
    BTW, you do have 'Hide extensions for known file types' turned off in Folder Options?
  6. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    are you sure you have the latest version or RAR or WinRAR?
