Please help if possible i have an Xbox 360 witch i want to plug into my LAN card of my PC via crossover cable.
I have setup a connection and set my internet connection to shared but when i test xbox live on my 360 it fails at IP confirm. This happens if i use automatically choose IP and DNS settings on PC and 360.
But if i manually set the IP adress on the 360 and PC i get passed the IP confirm test and it keeps failing at DNS check.
I don't know what i need to enter on the PC and 360 as DNS server address please help i have spent hours trying to sort the connection out.
I am using a 1mb cable broadband connection on a PC woth P4, 512 MB RAM, 128 MB GeForce FX 5200
Uhm... why not buy a router? Or at least a cheapo hub? Both of this get rid of the need for a crossover cable and frankly I've had issues with crossover in the past.
With a hub you should be able to turn on Internet Connection sharing on the XP box, put the settings into the Xbox and have it work like that.
With a router you should be able to set it up and plug all your stuff in. -
why not just unplug the ethernet cable from your PC and plug it into the XBOX?
are you gonna be surfing the internet on your PC at the same time that your trying to play games on your 360??"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!"
Connecting Xbox 360 to PC monitor
By man1mal in forum AudioReplies: 0Last Post: 14th Jun 2010, 09:21 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 06:19 -
Connecting Pioneer DVR-330-S to Xbox 360
By Dale08 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 27th Dec 2009, 03:38 -
Connecting XBOX 360 with 720p Plasma HDTV: So HDMI or Component Av Cable??
By jajabinks92 in forum DVB / IPTVReplies: 2Last Post: 29th Nov 2008, 08:16 -
Can you interchange a xbox 360 hddvd drive between pc and 360?
By yoda313 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2007, 09:06
