Hello,
I cannot use Cut/Join anymore in TMPGenc-MPEGTools. Sohow the created mpg files won't open anymore. When I select a mpg file, it looks like its getting opened, but no frame is being shown (just grey screen) and the file lasts "0:00:00".
I am 100% sure the mpg file is okay, and I've been using MPEGTools for over a year by now. But suddenly it stopped working.
After some research with Google I think it has something to do with a wrong video/audio codec, but I don't know which one.
Which should be installed and which one should NOT be installed.
The problem started after I installed TMPGenc 2.02 on my WinXP system. It did work for several movies, but suddenly it stopped working.
To make it even more strange; I've tried to re-install previous versions of TMPGenc, all gave the same problem EXCEPT for Beta 12a. This one could CUT/JOIN, but again after having done 2 movies it suddenly also gave up working.
ALL I wanna do is use CUT/JOIN, and I haven't found a better, easier program to do the job as easy as TMPGenc does. So I surely wanna keep using TMPGenc.
ANYONE ???
Really need help !
Greetz
Mars-L
WOWWWW
Think I finally solved it.
I saw more people have the same probblem so here's how I solved it;
I installed the MPEG2 codec that makes it possible to play DVD's under Windows Media Player.
Strangely enough I already could play DVD's under WMP, because I already had installed WinDVD.
But somehow this was the solution.
The MPEG2 codec can be found under the Tools section of this site;
http://www.dvd-wizards.com/vcdhelp/mpeg2codec_installer.zip
Greetz
Mars-L
How do I edit, cut, join DVDs, VOB, VIDEO_TS folders
By Baldrick in forum Authoring (DVD)Replies: 14Last Post: 8th Dec 2025, 10:01 -
mpeg4-ts - how to edit? Need to cut fragments and join two files
By relu84 in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2011, 07:01 -
Easiest way to cut and join video files
By zammil in forum Newbie / General discussionsReplies: 8Last Post: 15th Oct 2010, 12:04 -
Cut and Join VCD Files: tools that can Handle that
By devilcoelhodog in forum Authoring (VCD/SVCD)Replies: 5Last Post: 15th Jan 2010, 21:57 -
Good program from cut/join .mpg .wmv files.
By Beautiful Alone in forum EditingReplies: 1Last Post: 27th Jul 2009, 16:57
