Hi all
I have a friend whom as gone & bought these PDAs for their kids & 1 for her husband. Now i have just look @ some of the reviews to see if they can support they internet, but in the spec's none of them have bulit in wifi! what are the SD cards for them like?
PDAs
Acer n30
hp ipaq rz1710
acer n35
any help on this matter would be great
thnx
Results 1 to 11 of 11
The Acer is equipped with bluetooth. You could also depending on the LAN/WAN you could attach either SD Wireless LAN Cards or an SD 56k Modem Card. The Acers are capable of using both. The HP might be picky about which ones(models) it supports.
Beware. The cards can be expensive and you need to purhcase separate dongle cords. Check to make sure all accessories are included. A dongle can add $20-$30 to the price. -
if i used a linksys wireless router & used a wireless sd card for the pdas, would it pick up the signal?
thnx -
If the router and card are on the same band (A,B,G,N), Yes it will work fine. Your friend and kids will also be able to use the PDA at any hotspot that supports that band.
All Windows Mobile 2003+ Pocket PCs support SD WiFi cards so yes, you can use them. Since these only come in the "b" variety, there shouldn't be any compatibility problem.
HP Pocket PCs have no more difficulty using a SD WiFi card than any other brand of Pocket PC.
Be aware that low end PDAs tend to have relatively low amounts of internal memory and by using a SD WiFi card means that you cannot (simultaneously) be using a memory card.
I think that there are combo SD cards that have both memory and WiFi but for the cost, you might as well have bought a better equipped PDA to begin with.
Regards.Michael Tam
w: Morsels of Evidence -
ok, this there anywhere on the net where i can buy the sd cards tht i need cheaper? ( uk sites would be great)
thnx again -
"A" yes.
"G" (which is backwards compatible) no.
The vast majority of people do not have an "A" router and even if they do, they are often dual band (i.e., A and B).
Regards.Michael Tam
Most people I know have G but this is something that must be considered when looking to purchase WiFi Cards. I don't live in the UK. I purchase most equipment from US Companies.
you don't want cheap. When it comes to wireless you get what you pay for. I live in US and don't shop on UK sites.
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
PDA for Nursing
By romanstopme in forum ComputerReplies: 1Last Post: 10th Mar 2010, 20:53 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43 -
Connecting PDA to SMC wireless access point
By pchan in forum ComputerReplies: 0Last Post: 10th Sep 2007, 08:18 -
Convert DVD to play on a PDA
By underwurlde in forum DVD RippingReplies: 2Last Post: 1st Jul 2007, 03:01
