Is there any way to create a new timecode for a project in Premiere and superimpose it over the video? i.e. a timecode which starts at the beginning of the project, nothing to do with the original timecode for each clip.
Hi Rupert Bildge,
Which version of Premiere? I've used 6.0 and currently use 1.5 and I've not seen anything that will do it easily. That said, I've never needed to do it so haven't really looked for it.
It seems it can be done in After Effects, if you have that...
www.videohelp.com/forum/viewtopic.php?p=1419953#1419953
If you don't have any luck, try searching / posting in the forums at www.wrigleyvideo.com/videotutorial - an awesome site (check out the tutorials), even if you don't find what you're after...
If you do find the asnwer over there, post back here for others to see.
Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Rupert,
You have 3 options.
1. After Effects (mentioned above)
2. http://www.dve.nm.ru/ --> DV Date plugin for Premier e Pro
3. http://www.2writers.com/scripts/rd.dll?ID=1 --> Will generate a bunch of files that can be keyed out in Premiere Pro. -
A quote from that site:Originally Posted by aanaravs
"...print the timecode or shooting time information of the shooting made on a digital camcorder..."
However...
The DV Date plugin is certainly useful, but not in this instance for Rupert Bildge.Originally Posted by Rupert BildgeThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
different output option for premiere cs5?
By krohm in forum EditingReplies: 25Last Post: 23rd Jun 2011, 17:33 -
What's the best output option in Adobe Premiere Pro CS5?
By jeanpave in forum EditingReplies: 33Last Post: 12th Jun 2011, 10:55 -
Blurry output in Adobe Premiere Pro
By Thread7 in forum EditingReplies: 11Last Post: 10th Jan 2011, 09:40 -
Best HD settings output from Adobe Premiere for Youtube...
By mhdeaton in forum Video Streaming DownloadingReplies: 4Last Post: 11th Nov 2009, 23:15 -
Premiere Elements 7 -- cannot output 5.1 audio
By jg0001 in forum EditingReplies: 7Last Post: 26th Dec 2008, 00:58
