hi
apologies if this has been covered. I have borrowed a friend's Sony DCR HC21E mini Dv camcorder. I am trying, without success to transfer stills, captured onto the DV tape to my PC> I tried the help file/manual, but it only points me in the direction of transferring VIDEO to the PC, not what I have in mind. I do not want to capture the whole video, and then manually capture the still images, there must be another faster method?
I know (think) you have software that can search for, and "capture" these stills from the video tape. Unfortunately after some search, I havnt managed to find them.
Help urgently requested and much appreciated. (I do have extensive experience in capturing mini Dv and Digital 8 video to PC through Firewire)
regards
Kobus[/b]
Stills stored on tape are really just short video segments. You will probably have to transfer them as video, then take still screen captures. Stills stored to memory cards can have greater resolution and therefore quality than still stored to tape, which are restricted to standard video resolution.
Read my blog here.
guns1inger is right - I have a Sony miniDV that takes stills, and they're stored as the same frame (the "still") over a sis second period.
To get them to the PC, you have to treat them as video as, in effect, that's what they are - it's just that the same frame is repeated.
You can use WinDV to do this. You can then use VirtualDub on the resultant DV AVI to get a screen shot.
Problems:
1) I would imagine that the "still" would be an interlaced image - you'll need some photo editing software to work on the screen shot from VirtualDub to address the interlaced image.
2) The resolution is not going to be any bigger than 720 x 480 / 576 (NTSC / PAL).
You're better of buying a dedicated stills digital camera, or using a miniDV cam that takes stills to a card, not tape.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I can grab a single frame using the capture software from Ulead's MSP. I'd be suprised if there isn't something similar offered by the other capturing softwares.....
If your capture software uses a full size preview window you can use one of these techniques so you don't have to transfer the entire video: https://www.videohelp.com/forum/viewtopic.php?t=239865
Test of various VCRs Image Quality from VHS Tape (Big Pics)
By BrainStorm69 in forum RestorationReplies: 47Last Post: 2nd Aug 2013, 16:58 -
Transfer of real bad tape to pc and restore
By mammo1789 in forum RestorationReplies: 96Last Post: 9th Mar 2012, 23:38 -
Can this machine transfer from tape to disc?
By Janowski in forum Newbie / General discussionsReplies: 5Last Post: 19th Oct 2010, 14:23 -
DCR-HC42 Transfer Still Images from Tape
By MichaelRD in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2010, 23:09 -
DV tape damage during transfer
By syberkill in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 22nd May 2008, 22:03
