    Dec 2005
    India
    Hello Mates,
    please mates , can some one tell me like how to add pixelation etc to our MOVIE , like in some hollywood movies when there are some adults scene's the privates are not shown instead of them they pixelate those privates ,
    please any one can tell me how can we do that or which software i need to do that
    ! please thanks in Advance !
    Dec 2005
    You can add static pixelation using a filter for virtauldubmod which is pretty easy to do.
    Having the pixelation move around the screen with the subject is a bit trickier. Not sure if it can be done in virtualdub, but can be done in Adobe Premiere.Quick search came up with this - http://www.wrigleyvideo.com/videotutorial/tutdes_ppro_blurface.htm
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    The effect is usually called a mosaic. To track it you can either use either a built-in or plugin tracker (most compositing software has at least a basic tracker), or you will have to manually track the area using key frames. Once you have tracked it, you use the track to guide a mask that tells the effect which area to cover.
    Read my blog here.
  4. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    Or, you could download your porn from Japan. Problem solved!
