Newbie, latest vers on 10.3.7
trying out join avi and getting log :
OS Version: 10.3.7 (Build 7S215)
Report Version: 2
Command: ffmpeg
Path: /Applications/ffmpegX.app//Contents/Resources/ffmpeg
Version: ??? (???)
PID: 941
Thread: Unknown
Link (dyld) error:
dyld: /Applications/ffmpegX.app//Contents/Resources/ffmpeg Undefined symbols:
/Applications/ffmpegX.app//Contents/Resources/ffmpeg undefined reference to _exp2f expected to be defined in /usr/lib/libSystem.B.dylib
/Applications/ffmpegX.app//Contents/Resources/ffmpeg undefined reference to _sqrtf expected to be defined in /usr/lib/libSystem.B.dylib
Best
Klaus
I says in the error message.
It won't show up on a normal search, but if you open Terminal.app and write in "cd /usr/lib/ ; ls" (without quotes) you will see what's there. Chances are you won't find libSystem.B.dylib./Applications/ffmpegX.app//Contents/Resources/ffmpeg undefined reference to _exp2f expected to be defined in /usr/lib/libSystem.B.dylib
Edit: you can also use the "go to folder" command in the menubar in Finder (Shift+Command[Apple]+G).
I * found* libSystem.B.dylib exactly where you said, in usr...
so what's next ? ffmpegX is supposed to work in Panther *and* Tiger, at least it says so.
Thanks for hints, developers of ffmpegX
Best
Klaus
Can not log onto PC
By Noahtuck in forum ComputerReplies: 19Last Post: 12th Dec 2009, 21:35 -
Log in?
By alintatoc in forum ComputerReplies: 10Last Post: 5th May 2009, 01:04 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
Log in
By MintyJ in forum ffmpegX general discussionReplies: 3Last Post: 15th Mar 2008, 17:18 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
