I'm trying to author a DVD with 2 different audio tracks. I've dragged the audio tracks to the movie menu (both the same length) in DVD Lab Pro and gave them a category (English plus something else).
When I compile the DVD, it only sees one audio track, the first one.
I only wish to be able to toggle between the two audio tracks with the audio button on the DVD remote. I don't want anything fancy like an audio/subtitle menu.
How do I do this? What am I doing wrong? Thanks.
Results 1 to 18 of 18
Make sure the movie is shown in the main work area (looks like a film strip of thumbnails). Under than should be two audio tracks and a subtitle track. Drag audio one to the first audio track, then drag audio two to the second audio track. You should see a description of each audio track format in the track themselves.
If you just drag the audio to the movie you will simply be replacing one audio track with anaother, not getting two tracks.Read my blog here.
I definitely have the movie in the correct area and do have 2 audio tracks under it (Audio 1 and Audio 2). When I compile the DVD and play it back, only one audio track is selectable during playback.
I'm just wondering what else I maybe missing. -
When I've had two audio tracks I've created an extra menu which allowed me to choose which one I heard. Why do you have two tracks? General audio and commentary?
Bill -
The first thing i thought was what guns1inger said, the PUO.
I originally went over to DVD-lab PRO for the option of 2+ audio tracks.
Although having an audio menu to choose from is nice, i always make them, you don't have to have one to be able to switch between the audio tracks with the remote, unless the PUO was changed by mistake.
The last 3 dvd's i have authored in DVD-lab PRO have had 3 audio tracks and i've never had this problem -
Can you post a screen shot a copy of the compile report ?
You should also check the PUO (Prohibited User Operations) tomake sure you haven't blocked the audio button from use - consult your manual on thisI like it a lot so far, so may consider buying it.
The two tracks are for my home video. One for regular audio, and the other is just music. Home videos can be quite boring, so the option of having a soundtrack makes it more watchable.
I originally went over to DVD-lab PRO for the option of 2+ audio tracks. -
guns1inger - my compile result: (Verified my UOP's have no restrictions)
Damn, I don't have a place to put the image. Basically, it just says "Done!".
I have the following pre-compile options checked:
Create/Use Frame-Index for better Chapters accuracy
NTSC Safe Color
Reduce Jitter
And no other options checked. I have an "audio 1" and an "audio 2". No compile problems, I just can't use the 2nd audio stream when I play the video.
I can email you the screenshot if you want.... -
If you have put two sound tracks on the clip you should, I believe, see three audio tracks showing in the window - audio 1 (first audio track), audio 2 (second audio track) audio three (empty, waiting for the next track if there is one)
When you look at the movie window, in each audio track you should see a description of the centent (e.g. AC3 224kbps) - do you see something in each audio track ?Read my blog here.
On bottom (as far as bitrate is concerned), it lists 7505kbps + 384kbps + 384kbps = 8273kbps. -
They definately are there then. If you compile to the HDD, then playback with a sofrware player (PowerDVD, for example) can you access both tracks ?
What happens when you remove the working track and compile with just the non-working track? If you played it in Powerdvd do you hear anything?
Try that and if it works, check that the non-working track is in fact dual channel. It may be set to either left only or right only speaker. If that were the case it would not play in stereo mode but it would still let you toggle between your working audio and another blank audio in both powerdvd and your dvd player, you would just not hear anything on the second track.
If your dvd player isn't letting you toggle at all (try a working 2 audio disk just to make sure your dvd player menu settings haven't been messed with) and powerdvd see's no audio at all, I'd say to try re-encoding that audio.
Also try setting dvdlab restrictions back to standard. If you've relaxed them and there is something wrong somewhere, dvdlab won't give you the proper error message. -
I'm completely out of ideas at this point on why it doesn't work. -
I had the same problem with only one audio track compiling instead of all three.
I solved this by removing all audio tracks and adding them again.
It seems that DVDLAB forgets in some point that video has miltiple audio tracks and you have to remind him like that
Tomi Meglenov - http://www.normstudio.si -
I have this same problem with my DVD.
I try to make DVD with menu for two audio tracks for the same (the one and only) movie.
When I compile the DVD, everything works fine when playing in PC but not in DVD player.
I tried some VM commands too but I'm not sure if they are correct.
Maybe it's PRE and POST commands I need to set and reset the audio tracks (?)
Should I set the audio tracks from the audio menu by
Link -> Set Audio -> Audio Stream 1 (+ Go to first menu)
Link -> Set Audio -> Audio Stream 2 (+ Go to first menu)
or by
Link -> Set GPRM and Link....
Set GPRM
GPRM1=0
(for the first link)
GPRM1=1
(for the second link)
I'd try previous menu, not first menu, just to be sure
Link -> Set Audio -> Audio Stream 1 (+ Go to prev menu)
Authoring DVD with four subtitle tracks and PCM audio?
By bizzybody in forum Authoring (DVD)Replies: 7Last Post: 28th Feb 2010, 22:17 -
Help Authoring with DVD-Lab Pro
By PharmBoy in forum Authoring (DVD)Replies: 5Last Post: 14th Dec 2008, 22:28 -
authoring DVD with 2 audio tracks and soft subtitles
By Agent1266 in forum ffmpegX general discussionReplies: 6Last Post: 2nd Oct 2008, 15:34 -
Add a menu to a DVD without re-authoring, using DVD-Lab Pro
By petar in forum User guidesReplies: 38Last Post: 12th Mar 2008, 12:22 -
DVD Authoring with DVD LAB PRO doesnt create all files
By SSJ4Thiran in forum Authoring (DVD)Replies: 16Last Post: 18th Feb 2008, 10:03
