I'm getting a new scanner for Xmas and I'm thinking about the Epson 3490 ($100), Canon 8400 ($130) or the HP 4850 ($150). I will mainly use this for scanning text and photos like cd and dvd covers etc. and maybe film photos once in awhile but that will not be a priority. After some research there doesn't seem to be alot of differences in scanners unless you do alot of film scanning and then it seems you should spend a little money (say $250?). I think the above listed scanners are all pretty good but I'm leaning toward the Epson because it seems to do most things well without spending alot, does anyone have any opinions on the above scanners like which is the best value? Or maybe had good or bad experiences with the software that comes installed with each?
Also my brother is getting the HP 4850 for Xmas mainly because he says it's maximum scan size is 8.5" x 12.3" and he says it's important to him that when scanning text it scans larger than the standard 8 1/2" x 11" sheets of paper so he gets everything on the page. Now wouldn't all scanners made now do this without having to look specifically for one that does? I do know with some older scanners like my (Canon 620?) you have to arrange 8 1/2" x 11" sheets just right on the scanner or it will leave part of the page off. So Is it important to look for scanners that scan larger than standard printer paper to get the whole thing scanned right if scanning text is important?
Results 1 to 9 of 9
First you can tell your brother that all three of these scanners have a maximum scan surface of 8.27 in. x 11.69 in. or A4 paper size. This is plenty big for normal scanner usage. The HP has a higher optical resolution but it achieves this via software and will produce those scans much slower than both the canon and epson because of it.
Given these choices, I'd opt for the Epson. Why? My personal preference for scanning is all. -
If you want to scan documents larger than that with one scan you need one with a bigger bed. All current scanners will scan a normal sheet of paper fully.Originally Posted by mccoady
How do you define normal? Letter Size? Legal Size? A4? A3? B1?
My scanner, an Epson, will scan 11.5 x 17 in one scan. -
The standard 8.5 x 11 that I and everyone else use the most. (at least in the US)Originally Posted by ROF
I'm sure your defintion varies.
Nope, I'm in the US too so letter size is what I would call normal as well.
Good that's what I wanted to know that all current scanners would indeed scan the full page without leaving something off. I was never really seriously considering the HP until my brother brought that up and it does have a larger bed (8.5x12.3) so maybe he needs that to scan things I'm unaware of.
I was really trying to decide between the Epson and the Canon. The Epson 3490 is a new model with hardly any use reviews yet, although it has been sort of reviewed by PC Mag and PC World but I didn't know how much credence to put into them. The Canon 8400 is an older model and has plenty of good reviews although the physical size is quite large. So I was leaning toward the Epson because of the smaller size and hoping it would compare closely to the Canon in performance. -
I'd go with the Epson. I simply enjoy the Epson line of scanners. Canon is good too, but with the price difference and similiar specs of both, I'd go with the Epson.
slide scanner needed and question
By mazinz in forum ComputerReplies: 6Last Post: 11th Apr 2010, 17:51 -
Old scanner...
By alegator in forum ComputerReplies: 18Last Post: 26th May 2009, 17:17 -
I Need A New Scanner
By RenoLuna in forum Newbie / General discussionsReplies: 5Last Post: 1st Dec 2008, 17:25 -
question about how to use Gmer malware scanner/deleter
By jimdagys in forum ComputerReplies: 3Last Post: 10th Apr 2008, 08:54 -
scanner help
By Mr anderson in forum ComputerReplies: 7Last Post: 18th Jan 2008, 12:08
