    Dec 2005
    New Zealand
    I've been using a cheap Panasonic camcorder (NV-DS60) to convert analog video into DV in real time for capture. I plug the analog source into the camcorder AV input and the Firewire output from the camcorder to the PC. Usually it works great but sometimes with older VHS tapes I get picture breakup.
    My question is this: Would there be a difference in performance if I bought a dedicated analog/DV converter? Or maybe a more expensive camera? Or is the conversion to DV going to be pretty much the same?
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi Rupert Bildge,
    Welcome to the forums.
    I don't know for definite, but my guess would be that a different / better analog-DV converter would make little or no difference. My efforts (if it were me) would be aimed at improving the input: a better VCR, clean the heads etc.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    As daamon suggested, or a TBC may help as well.
    https://www.videohelp.com/forum/viewtopic.php?p=1115672#1115672
    There's a image posted above where that libk goes, you may need to refresh or lokk for it because once the image downloads you lose the spot on the page.
    Dec 2005
    New Zealand
    Thanks guys. I should have mentioned that I am planning on borrowing a TBC in a couple of weeks. I have tried the built-in TBC on my Panasonic HS-1000 but it made no difference. I'm hoping a professional frame-store TBC might be better.
    I just want to make sure I have the best capture system in place with no weak links. I've always thought that using a camcorder is pretty much as good as a dedicated converter but now that I can afford to buy specialist tools I'm willing to do it if it makes a difference (even a small difference). However if it makes no difference at all then I'm happy to stick with what I've got.
