As I understood from reading this forum, all or most Bone camcorders have the pass through option. In pass through analog video signal enters the camcorder's analog input, while the camcorder's firewire output is fed to a PC (or any other firewire input video recording device). This way, the analog video signal get stabilized by the Sony passing through camcorder.
Questions.
1. Is my understanding correct? If not, what is correct about pass through?
2. Does the quality, or degree, of stabilization in the pass through by Sony camcorders is good enough so that one wouldn't need a TBC in cases of very unstable video source, like VHS tapes?
3. If the answer to question 2 is "yes" -- is there any advantage to a TBC over pass through?
4. Does stabilization occur on all Sony camcorders that have pass through, including Digital 8 ones, like TRV460?
5. Does the same degree of analog signal stabilization is achieved by using the pass through of WinDV (though in this case the input should be firewire)?
I have a Sony DVD8 TRV120 (PAL) and use it a lot for A/V passthrough
Answers:
1. You are correct, that is how I use my camcorder too.
2. I digitized quite a lot of VHS stuff now this way and all with very good results. It even bypasses the Macrovision signal through the firewire(But I don't know if the newer models do the same).
3. I really can't say, possible there are higher quality solutions around but at a price. The passthrough option just makes great stable captures for me.
4. My guess is all the Sony camcorders with analog in use the same principe as part of their analog to DV conversion.
5. I don't know exactly what you mean, WINDV just copies digital data. Nothing will change there. -
https://www.videohelp.com/forum/viewtopic.php?p=1115672#1115672 -
Originally Posted by thecoalman
All horizontal movement/jitter often present when when capturing a unstable (VHS) source is removed resulting in a rock steady picture.
I can cleary see the difference when I use my other capture devices (BT848 card, Hauppauge PVR150). -
Digital camcorders that have analog pass-thru & TBC
By djnice in forum Capturing and VCRReplies: 30Last Post: 19th Jul 2020, 03:57 -
Several questions about "pass through" and Sony/Canon camcorders
By tadd5181 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 9th May 2010, 12:42 -
Sony TRV 138 or TRV 350: do these camcorders have "pass through"?
By tadd5181 in forum Video ConversionReplies: 1Last Post: 24th Apr 2010, 18:38 -
WinDV dropped frames - SOME camcorders, not all?!
By 2Bdecided in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 11th Mar 2010, 03:44 -
Why won't MiniDV camcorder pass signal through to external firewire drive?
By KeepItSimple in forum MacReplies: 12Last Post: 24th Oct 2008, 07:49
