I'm running 10.2.8 and am trying ffmpegx 0.0.9k. Can I use ffmpegx to convert the newer "QT-7 required" trailers to something either VLC or QT 6.5.x can play? If so, what settings do I use? So far, no luck with the "Cars" trailer.
As an aside, every time I restart ffmpegx, it asks me to locate mplayer - why does it not remember where mplayer is?
Thanks.
0.0.9k is quite old and perhaps the H264 decoder was not very present at the time. If it asks each time to locate mplayer it may be because you installed a version different than the recommended one for 0.0.9k.
Epson R220 "Service Required"?
By videobread in forum MediaReplies: 25Last Post: 11th Aug 2012, 11:05 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
Why are they called movie "trailers" if they come BEFORE the movi
By yoda313 in forum Off topicReplies: 15Last Post: 23rd May 2009, 10:38 -
"Check to make sure you have the required codec"
By andy_blah in forum SubtitleReplies: 2Last Post: 8th Aug 2008, 12:58 -
I've got an "MP4" (AMV Conversion required) player
By marktodd in forum Portable VideoReplies: 2Last Post: 9th Aug 2007, 06:56
