Attempting to encode a VOB source produced in iMovie (vid: mpeg-2, 720x480, 7000kbps, 29.97fps; audio: dvdpcm, 48000htz, 1536 kbps)
to iPOD H.264 pre-set. In every trial no audio is produced (I tried audio tracks 0 thru 2). The source VOB plays well with "play" and "info" recognizes the audio source above. iPOD - TV pre-set encodes video and audio very well using same settings.
Help -- Anyone
major, per your request here is process report. The video stream plays well with VLC but no audio stream. Thanks, Harley
ffmpeg version CVS, build 3277056, Copyright (c) 2000-2004 Fabrice Bellard
Wed Dec 7 22:25:02 MST 2005
Mac OSX static build for ffmpegX
configuration: --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264
built on Dec 1 2005 03:50:24, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
Input #0, mpeg, from '/Users/harleyrobertson/DVDRips/YOSEMITE2005 Title 1 (Ch1 - Ch3)/VIDEO_TS/YOSEMITE2005 Title 1 (Ch1 - Ch3).VOB':
Duration: 00:31:04.6, start: 0.257200, bitrate: 9446 kb/s
Stream #0.0[0x1e0], 29.97 fps: Video: mpeg2video, yuv420p, 720x480, 8000 kb/s
Stream #0.1[0xa0]: Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
Output #0, yuv4mpegpipe, to 'pipe:':
Stream #0.0, nan fps: Video: rawvideo, yuv420p, 320x176, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
x264 [info]: using cpu capabilities Altivec
mp4 [info]: initial delay 0 (scale 29970)
video:0kB audio:0kB global headers:0kB muxing overhead inf%
x264 [info]: slice I:268 Avg QP:27.88 size: 8262 PSNR Mean Y:37.18 U:42.41 V:43.54 Avg:38.33 Global:36.50
x264 [info]: slice P:55617 Avg QP:30.93 size: 782 PSNR Mean Y:33.51 U:40.06 V:41.33 Avg:34.81 Global:33.06
x264 [info]: mb I I16..4: 24.2% 0.0% 75.8%
x264 [info]: mb P I16..4: 1.9% 0.0% 0.3% P16..4: 61.2% 0.0% 0.0% 0.0% 0.0% skip:36.6%
x264 [info]: final ratefactor: 27.97
x264 [info]: PSNR Mean Y:33.532 U:40.067 V:41.339 Avg:34.832 Global:33.074 kb/s:196.19
encoded 55885 frames, 20.16 fps, 197.43 kb/s
error: movie contains no audio tracks!
Can you send me a small clip of this kind to major4@mac.com (it can be up to 1GB if you use yousendit.com), so as I can test and find the fix.
vob 2 video + audio then increase audio volume then recombine to vob or mpe
By indyram in forum Authoring (DVD)Replies: 6Last Post: 14th Dec 2011, 02:55 -
From Vegas to iMovie - Does the version of iMovie matter?
By and in forum EditingReplies: 4Last Post: 11th Dec 2011, 21:05 -
iMovie HD audio problem with transitions
By piperpilot12w in forum MacReplies: 2Last Post: 10th Jun 2010, 01:47 -
VOB to MPEG to MOV to export to iMOVIE HD 06 HELP PLEASE!
By HowardNeedsHelp in forum MacReplies: 5Last Post: 16th Aug 2009, 07:15 -
Importing VOB files--iMovie, Final Cut Express? New to Mac
By Theresa in forum MacReplies: 14Last Post: 7th Apr 2009, 09:54
