  1. Hi,
    If I edit MPEG 1 files after making them in TMPGEnc using Ulead Media Studio and then save them as MPEG 1 will I loose quality?
    What I would like to confirm is whether or not the MPEG file is encoded again and if so what is the end result in quality?
    The reason for not editing the AVI files prior to encoding is shortage of disc space as the AVI file is over 10 Gb.
    Take care
    Dave
    Dave Knowles Films
    Southampton - UK
  2. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    On 2001-12-26 03:11:15, Dave Knowles wrote:
    Hi,
    Make sure the avi is good quality.I have yet to see any substantial quality loss when converting.As for space,if your avi is 10 gb,and your converting to mpeg,your output file is going to be at least twice that if not more! I have
    Media Studio,but I really only use Tmpge or virtua dub,both free.
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
  3. Member vhelp's Avatar
    Mar 2001
    New York
    Dave, (oops, not count)
    It may or may not be re-encoding your mpeg file. Probably depends on several
    factors, like if you're using ANY special affects ( trans/overlays, etc. ) ...just the
    slightest and there will be some (though minor) re-encodes or partial encodes
    from the edited part of the clip.
    I experienced this with MPEG2VCR. Took me a while before I decided to pretty
    much give up on it, unless I have to use it. I would use MEPG2VCR to cut whole
    MPEG2 files into pices - a great app to use for this, BUT, theres this nasty glitch
    of studdering or jerkeyness when you're playing your CD in a dvd player and you
    press the skip button to the next clip or when you clip finishes and moves on to
    the next clip. It would studder like for 1 to 2 seconds. Gets kind of annoying
    after a while.
    I don't know if Ulead has these same issues, but you may want to make note of
    this glitch if it concirns you.
    I was wondering about your process - capture/encode/edit/burn/play in dvd...
    * R U cutting out commercials and things?
    * Have you used Virtualdub? You can use VD and cut your commericials out
    and frameserve to tmpg into a one large mpeg or into separate mpeg clips and
    burn to cd. I use this method cause I can make sep. clips and use my skip key
    on my report during dvd playing. much easier then setting up a menu or whatnot
    or FF'ing to scenes.
    - vhelp
    <font size=-1>[ This Message was edited by: vhelp on 2001-12-26 18:59:20 ]</font>
