Hello All!
I am having a problem decoding AC3 streams created by MTR rips. Yes, I am a legal owner of the DVD in question. This happens regardless of what the target file is (AAC/MP3/MP2). Anyway, when I try to encode any AC3 stream ripped via MTR in ffmpegX 0.0.9u, I get errors indicating that it could not decode the stream. This was not a problem in previous versions of ffmpegx.
The really weird part is that ffmpegx 0.0.9u **CAN** decode AC3 streams from HDTV recorded from my EyeTV500.
So what's going on?
-STS
Major,
Here is the terminal output:
Encoding started on Tue Dec 6 12:31:52 EST 2005
ffmpeg version CVS, build 3277056, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX static build for ffmpegX
configuration: --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264
built on Dec 1 2005 03:50:24, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
Input #0, mpeg, from '/Volumes/Video/DVD Title 1 (Ch1 - Ch1)/DVD.VOB':
Duration: 00:04:09.3, start: 12.578500, bitrate: 6067 kb/s
Stream #0.0[0x1e0], 29.97 fps: Video: mpeg2video, yuv420p, 720x480, 9800 kb/s
Stream #0.1[0x20]: Subtitle: dvdsub
Stream #0.2[0x21]: Subtitle: dvdsub
Stream #0.3[0x22]: Subtitle: dvdsub
Stream #0.4[0x23]: Subtitle: dvdsub
Stream #0.5[0x80]: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
Stream #0.6[0x81]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #0.7[0x82]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Codec type mismatch for mapping #0.1 -> #0.0
If this error is related to a poor method of ripping from MTR, please let me know, but I didn't have this problem in the s or t revs of ffmpegX.
-STS
For comparision, this is the output when the same task is attempted with an EyeTV500 HDTV/AC3 file:
Encoding started on Tue Dec 6 12:36:06 EST 2005
Input #0, mpegts, from '/Volumes/Video/EyeTV Archive/0000000008eb62e1/0000000009436a12.mpg':
Duration: 00:04:00.7, start: 29853.177344, bitrate: 12442 kb/s
Stream #0.0[0x31], 59.94 fps: Video: mpeg2video, yuv420p, 1280x720, 38810 kb/s
Stream #0.1[0x34](eng): Audio: ac3, 48000 Hz, 5:1, 384 kb/s
Output #0, mp2, to '/Volumes/Video/EyeTV Archive/0000000008eb62e1/0000000009436a12.mpg.ff.mp2':
Stream #0.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
Stream mapping:
Stream #0.1 -> #0.0 [sync #0.0]
Press [q] to stop encoding
size= 6581kB time=240.7 bitrate= 224.0kbits/s
FFMPEG decoding WMV to FLV problems
By motorg in forum Video ConversionReplies: 3Last Post: 10th Aug 2009, 22:30 -
Problems decoding FLV4/VP62
By drwho in forum Video ConversionReplies: 1Last Post: 1st Mar 2008, 19:16 -
DVD decoding problems with TMPGEnc 3.0 XPress
By shorto in forum Newbie / General discussionsReplies: 2Last Post: 21st Aug 2007, 13:16 -
DirectShowSource() reliability problems for DV decoding in AviSynth().
By towtruck in forum Video ConversionReplies: 4Last Post: 28th May 2007, 10:43
