  1. all,
    i know the basics of putting together a static background menu image, a motion menu clip and audio in dvd lab pro.
    my question is, can i have a different length motion menu clip and audio?
    example: a video clip that runs for say 20 seconds (repeating) with an audio running say 100 seconds?
    currently, i think dvd lab pro extends the 20 second clip 5 times to occupy the 100 seconds needed for the audio. is this right?
    is there a way of doing the above without "bloating" the video clip?
    Apr 2004
    Miskatonic U
    They have to be the same length. This is a limitation of the spec, not the sofware.
    Read my blog here.
  3. okay kokey guns1inger. won't argue with you. will make do with same length sequence.
    thank you very much. virtual beer has been posted to you.
