On my Boondocks Saints DVD I want the song at the main menu, Is there a way to rip that song?
Thanks Brian 8)
Find which of the VOBs the menu is contained in (in the VIDEO_TS folder of the DVD, drag them into PowerDVD or Media Player Classic till you get the right one), then demux the audio. You can use Virtualdubmod for this.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Ok I got the program, I keep getting an error
"no audio compressor found to decompress the source audio format" -
Install one of the AC3 codecs found here https://www.videohelp.com/tools?s=6#6
Read my blog here.
Hi-
You can use DGIndex for the same purpose. Load the Vob containing the menu, and then go File->Save Project. It'll demux the AC3 by default. At least I think it's default. Go Audio->Output Method, and see if "Demux All Tracks" is checked. You can also convert it to WAV at the same time if you want by checking the box at the same place
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
forced subtitle problem in avi.net with dvd rip of main movie only
By nathanm in forum SubtitleReplies: 0Last Post: 30th Apr 2010, 09:37 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 19:27 -
How to full backup (no encoding) BR main movie, main audio with subtitles ?
By meico1234 in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2009, 03:37 -
Rip DVD menu audio
By Silver_Ice in forum AudioReplies: 7Last Post: 27th Mar 2008, 23:33
