I couldn't thank you all enough. I got it working with jimmalenko's link to http://members.dodo.net.au/~jimmalenko/test.htm#ifoedit. The problem was my set top dvd player. I tried it on another player and it works fine. However, there is a slight quality issue and I'm not sure if this is due to converting from a double layer to a single layer dvd media. Every other second or so the picture would look kind of blurry...at least on the enders of a character. So anyway, thanks again. It works. I would assume that the quality may be due to conversion issue.
Results 31 to 31 of 31
How to author & burn a DVD from VOB trailers/files
By Baldrick in forum User guidesReplies: 62Last Post: 30th Sep 2011, 05:39 -
Does re-authoring VOB files with TMPGEnc DVD Author, or DVD-lab better
By MarcMiller in forum Video ConversionReplies: 6Last Post: 16th Nov 2010, 00:31 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15 -
How do I Author an HD-DVD using mkv files....
By ronorkis in forum Authoring (DVD)Replies: 2Last Post: 10th Dec 2007, 11:47
