  1. Hi,
    Its been a while since i've used my SVCD2DVD program.
    Is there an explanation of all the options in it?
    Two Pass encoding
    Use pulldown
    Pan and scan info
    Audio options
    Etc etc.
    Can anyone please help me with this? Really like to find out what they all do/meen, especially any ones that help the quality.
  2. Two pass encoding is exactly that. Version 2 will convert AVI files to DVD compliant MPG files. Two pass encoding results in a higher quality conversion.
    Pulldown is used in the same instance (AVI) and converts NTSCFILM AVI's at 23.976 fps to display at 29.97fps for compliance.
    Pan & Scan info I believe has to do with certain pioneer players being picky about SVCD conversions.
    Someone else can jump in for the audio options or to add to (or correct) what I have said.
