I haven't used ffmpeg for awhile. I used it awhile back and it made me a hero. I saw the new upgrade on Versiontracker and wanted to try out the new iPod presets. The older version I had wasn't a pay version and I wouldn't mind paying if I can get this problem solved. When I updated, I just overwrote the old one. I tried to update the mencoder and mplayer and that seems fine, but when I tried to update the mpeg2enc I had problems. The file would download as text(.txt). I tried again the other day and it came up differently but still not like the others (a Unix file) rather a document with no application assoicated. I tried to use it as a binary and no error message. So, I then tried to convert a few files and no luck. The file created would be only 4KB and nothing played back. The files I tried to convert are from iMovie and saved as mjpeg files. I don't know what to do next. I used to keep the binaries in a folder my Movies folder. I have tried moving them into ffmpeg folder in Application support. I can see several places where I could have done things smarter but I don't know where to go from here. Is the issue the mpeg2enc file? What should I do? Just a note, the play button in ffmpeg works fine but preview does nothing when i try it.
The 188,524 bytes file is the right one. The installer will copy it and turn it into a Unix Executable File.Originally Posted by drgnflyz
After the installer is done with them, you may delete the downloaded binaries.Originally Posted by drgnflyz
The mpeg2enc engine is only used for MPEG-1/-2 encodings, not the iPod presets.Originally Posted by drgnflyz
More information is needed. Like the Log output (Originally Posted by drgnflyz
Only functional while encoding.Originally Posted by drgnflyz
Hey Case,
Thanks for your reply! I verified my mpeg2enc and I appear to have the right one. Here is log that you mentioned: Encoding started on Mon Dec 5 17:52:06 PST 2005
x264 [info]: using cpu capabilities Altivec
mp4 [info]: initial delay 0 (scale 29970)
ffmpeg version CVS, build 3277056, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX static build for ffmpegX
configuration: --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264
built on Dec 1 2005 03:50:24, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
Seems that stream 1 comes from film source: 2997.00 (2997/1) -> 30.00 (30/1)
Input #0, mov,mp4,m4a,3gp,3g2, from '/Users/tbarclay/Desktop/AutumnBirthday.mov':
Duration: 00:02:38.1, start: 0.000000, bitrate: 7787 kb/s
Stream #0.0: Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
Stream #0.1, 30.00 fps: Video: mjpeg, yuvj420p, 640x480
Output #0, yuv4mpegpipe, to 'pipe:':
Stream #0.0, nan fps: Video: rawvideo, yuvj420p, 320x240, q=2-31, 200 kb/s
Stream mapping:
Stream #0.1 -> #0.0
[yuv4mpegpipe @ 0x45a0e4]ERROR: yuv4mpeg only handles yuv444p, yuv422p, yuv420p, yuv411p and gray pixel formats. Use -pix_fmt to select one.
Could not write header for output file #0 (incorrect codec parameters ?)
x264 [info]: final ratefactor: 48.33
/Users/tbarclay/Desktop/AutumnBirthday.mov.ff.mov.video.mp4: could not find codec parameters
Hope this helps.
I tried again twice also from another Mac. The other Mac was fine but the file it was changing from was already H264 but a .mov file. when I tried the one I was working on it seemed to create 2 files. One 0KB the other 5.4MB when I tried to play it back nothing played. The player looked like it was just playing an audio file, no picture window. Here is the log created: Encoding started on Tue Dec 6 18:31:31 PST 2005
movtoy4m
Copyright 2002-2005 Johan Lindstr??m
All rights reserved. Used in ffmpegX under license.
x264 [info]: slice I:25 Avg QP:15.12 size: 17964 PSNR Mean Y:51.37 U:53.66 V:54.07 Avg:52.01 Global:48.59
x264 [info]: slice P:4714 Avg QP:17.72 size: 1106 PSNR Mean Y:46.56 U:48.04 V:47.92 Avg:46.87 Global:44.56
x264 [info]: mb I I16..4: 15.8% 0.0% 84.2%
x264 [info]: mb P I16..4: 2.2% 0.0% 2.0% P16..4: 50.5% 0.0% 0.0% 0.0% 0.0% skip:45.3%
x264 [info]: final ratefactor: 21.34
x264 [info]: PSNR Mean Y:46.589 U:48.074 V:47.955 Avg:46.892 Global:44.574 kb/s:286.41
encoded 4739 frames, 59.34 fps, 287.67 kb/s
Seems that stream 0 comes from film source: 29970.00 (29970/1) -> 29.97 (30000/1001)
Input #0, mov,mp4,m4a,3gp,3g2, from '/Users/tbarclay/Desktop/AutumnBirthday.mov.ff.video.mp4':
Duration: 00:02:38.1, start: 0.000000, bitrate: 288 kb/s
Stream #0.0, 29.97 fps: Video: h264, yuv420p, 320x240
Input #1, mov,mp4,m4a,3gp,3g2, from '/Users/tbarclay/Desktop/AutumnBirthday.mov':
Stream #1.0: Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
Stream #1.1, 30.00 fps: Video: mjpeg, yuvj420p, 640x480
Codec type mismatch for mapping #1.1 -> #0.0
Thanks for the response. It worked. However, I didn't think so at first. Couple things I think are odd. 1st, the percentage on the encoding went up to 121%, 2nd it still created 2 files at first, one labelled video the second audio. I tried to play and same old results but then a few seconds later the familiar done chime came through and the files merged into one. It played fine. I'm wondering if I was patient before and if all the changes mentioned really did the trick.
Major please don't take this as griping. I think this is what I want for an app. I want to be able to keep full quality files for my originals and then just a quick encode to my iPod. The idea of fine tuning is great for some situations but for the most part I just want presets to drag and drop into for my everyday needs. I'm really surprised Apple hasn't built presets into iMovie or QT Pro. Maybe, that is how they will get people to upgrade to the next iLife. In the end, my check will be in the mail to Paypal.
FFMpegX Audio problems
By Cowchan in forum Newbie / General discussionsReplies: 0Last Post: 11th Dec 2011, 11:00 -
Upgrading M/B & CPU, no other existing hardware, likely problems ???
By blinky88 in forum ComputerReplies: 5Last Post: 15th Aug 2008, 16:02 -
Likely problems upgrading motherboard from sis650 to sis651 chipset
By blinky88 in forum Newbie / General discussionsReplies: 1Last Post: 11th Aug 2008, 15:34 -
Problems with ffmpegX
By KeepItSimple in forum MacReplies: 2Last Post: 5th Apr 2008, 21:46 -
ffmpegx Problems! Help!
By The Sumerian in forum ffmpegX general discussionReplies: 4Last Post: 10th May 2007, 01:36
