hi ! After I Moved my Movies-files from Digital Cam with Windv software, i try to open the AVI file, and i get this msg :"Couldn't locate decompressor for format 'dvsd' (unknown). VirtalDub requires a Video for Windows (VFD) compatible codec to decompress video. Directshow codecs such as those used by Windows Media Player are not suitable Only 'Direct stream copy' is available for this video" . I Need help to know what is missing in my system and from where can i get it.
tnks
Results 1 to 11 of 11
do a search for mjpeg
your missing a DV VFW codec (Video for Windows)
Windows has a directshow codec for playing DV, but Virtualdub needs a VFW one
thekid... -
If i have a Sony Cam, can u tell me from where can i found this missing codec and download it & how to install it?
Just update your version of VirtualDub, version 1.6 has a built in DV decoder (but not encoder). Otherwise download the Panasonic DV codec (VFW) codec if you want to encode DV in VDub as well.
Edit: BTW, did you save as a Tyoe 1 or Type 2 DV AVI from WinDV - the older VDub versions don't work with Type 1 DV AVIs?"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
i thought he meant a digital camera (i.e. a 'cam') -- but if he means a dv camera , yes - install a dv codec ...
I update my version of VirtualDub to version 1.6 and alsow install Panasonic DV codec (VFW) codec . Evrything is working now. t n k s all !!!
What is the deferent between the Type 1 or Type 2 DV AVI from WinDV and with wich type shuld i use ? -
Stick with Type 2 for best compatibility with most editing programs. For an explanation of DV Types, see the Glossary entry https://www.videohelp.com/glossary?D#DV
Missing Codec?
By jimbb in forum Newbie / General discussionsReplies: 7Last Post: 4th May 2011, 14:54 -
Codec missing virtualdub
By tkitez in forum Video ConversionReplies: 25Last Post: 12th Jan 2011, 20:42 -
Missing a codec?
By jnojr in forum Newbie / General discussionsReplies: 5Last Post: 2nd Dec 2008, 17:24 -
Codec missing
By breeze9 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2008, 21:08 -
Missing Codec
By arileysr2 in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2007, 13:13
