PestPatrol has detected that Gabest MPC has an adware.
http://www3.ca.com/securityadvisor/pest/pest.aspx?id=453083020
Is this true?
Closed Thread
Results 1 to 30 of 31
I believe this was reported some time ago. It's not really adware but spyware. There is connection made between a gabest server and your machine when connected it attempts to read what files you've been playing with the media player. No harm really IMO unless it's sending pop-ups as well now.
Umm, looking at the link you posted, the only "spyware" indication from ca.com is that there is a "recent file list" entry in the registry? That's it? Many programs have that. That by itself does NOT indicate a piece of spyware.
Also, take a look at the forum discussions for the project at SourceForge:
http://sourceforge.net/forum/message.php?msg_id=3151838
and
http://sourceforge.net/forum/message.php?msg_id=3092310
I would take the developer's word for it, as well as one of the replies by celtic_druid (frequent contributor here as well). Or grab the source and check it out for yourself, since it is an open-source project.
There is no evidence backing up ROF's assertion, so feel free to use it comfortably.
Jim
For that matter the link provided specifically claims that MPC is adware:
MPC is very obviously not adware, so this entire entry is suspect at best. The spelling "assocaited" is quoted directly from the source.Gabest Media Player Classic
Overview
Category
Adware : Software that displays popup/popunder ads when the
primary user interface is not visible or which do not appear to be
assocaited with the product.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
hahaha good point.Originally Posted by drjtech
Now that I think about it isn't MPC open source? I mean you can just check the code right?
Bah it got messed up but oh well. Please check here.
http://www.crystalmidnight.com/true.html
All it takes to be an expert is a keyboard.
As far as I see the only record it makes is a list of recently opened files, if that is considered spyware I have a shitload of spyware on my comp then. Just about every app I have installed has a recently opened files list.... Matter fact I guess we can classify Windows itself as spyware since it too has it's own recent documents list.Originally Posted by ROF
That's four times you stated it's spyware, if anything it prevents spyware since you don't need to install all the baggage that comes with Real Media software..... You're putting down a fine FREE open source project that someone has labored to make
.....show me where it's spyware, don't state it, show me. The fact that it's open source just about negates any possibility of it containing spyware since anyone with knowledge can examine the code to see what it does.
Otherwise see this thread: https://www.videohelp.com/forum/archive/t244978.html
Is this really an issue for you? I know it doesn't bother me. As a matter of fact, I don't mind most spyware located on my machine even those that phone home. I've gotten some fantastic deals on products which I can blame on spyware keeping track of my activities. There's good and there's bad spyware. Just like there is good rootkits and there are bad rootkits. It depends on the it's purpose. This one is benign.Originally Posted by thecoalman
What's an issue for me is the fact that your spouting complete bullshit. Someone goes through the trouble of creating a software and you say it's spyware. It's nitwits like you that are detriment to the open source community who spend a lot of their time freely to create things for the rest of us. Get your facts straight or don't post them... Again where is the proof, you've only stated it's spyware and try and steer the topic elsewhere, you and that misleading link above are the only thing that point it out as spyware. None of the major spyware detection vendors consider it spyware, do you know something the rest of us don't know? Proof... I want proof.... Show me.... teach me..... Let me learn....Originally Posted by ROF
You can't can you?
Arguementative.
Sorry I've already explained this to you now how many times?
By definition Spyware is a general term for a class of software that monitors the actions of a computer user. The proof is in the original link. Spyware detection software is only good when and if the spyware is transmitting the info.
For example, Whenever I use Kazaa I get a warning from my spyware protection that Kazaa is spyware and it asks if I want to block it. Most of the time Kazaa just resides on my system without ever setting off the spyware detection system. Spyware detection software only functions when and if it's transmitting data. It's internal collection methods are never trapped by this software otherwise your windows restore software would set it off every few seconds.
You could have hidden programs that are set to transmit data once a week, month, or year. Maybe you even have Spyware installed that is set to transmit at a specific date. Maybe you have spyware that never transmits it's data collection. Nevertheless, this is spyware by definition.
No you have not explained anything, you're not smart enough to explain anything to me, you just keep saying it's spyware... and you still haven't explained anything. If your proof is the original link then nearly every piece of software on the internet is spyware.Originally Posted by ROF
start>run> type regedit .... edit>find and type recent, recent documets , recent files .... you'll find multiple instances of this from multiple vendors. So by your proof you're saying any software that logs recent files which includes windows and every other piece of software that I use that works with other files is spyware?
The definition of spyware (from dictionary.com):
Of course there are other definitions, but the common thread involves transmission of the information back to some entity. Since Media Player Classic transmits no information to any entity, it is not spyware.any software that covertly gathers information about a user while he/she navigates the Internet and transmits the information to an individual or company that uses it for marketing or other purposes
Additionally, many programs use the registry, or ini files to maintain a MRU list for the convenience of the user. As long as that information is not transmitted to any entity, they are not spyware.
Dictionary.com defines spyware as:
Since this log is never transmitted back to gabest's website/server, then I would hardly call it spyware. It is simply for the user's benefit to recall files that have been opened previously for the player. As mentioned previously, the sourcecode is available for anyone to look at, if they feel that there is covert code that transmits this data back home.any software that covertly gathers information about a user while he/she navigates the Internet and transmits the information to an individual or company that uses it for marketing or other purposes
On a personal note, I myself have been accused of putting spyware into a program I wrote, simply because a flimsy anti-adware tool scanned the working directory of my utility and found a file(gm.exe) that had the same name of a reported spyware program. It can be very frustrating when these anti-ad/spyware tools either have bad information, or do not fully scan for the correct signatures in a file.
edit: totally missed Vegasbud's post. Looks like we had the same thought.
it dosnt have to be "transmitting the info" to be detectedOriginally Posted by ROF
see aboveSpyware detection software only functions when and if it's transmitting data.
what???It's internal collection methods are never trapped by this software otherwise your windows restore software would set it off every few seconds.
Sony's latest Rootkit does not transmit any information, is it Spyware? Remember the rootkit is not setup to transmit any data. All it does is gather such info about you and your habits. Like all good spyware it has the potential to be exploited for malicious purposes though.Originally Posted by VegasBud
AFAIK that has only been labled a POS that can screw your computer up and make it vulnerable to spyware and viruses. I don't think the rootkit has been officially labled spyware. The media player on the other hand has been labled spyware, Ithink you have your software mixed up.Originally Posted by ROF
Perhaps you could contact Microsoft and tell them that adding the detection and removal of this Sony Rootkit to their AntiSpyware software package is incorrect.
BTW, the MPC software has been incorrectly labeled adware not spyware as you now correctly claim it as.
Adware spyware whatever.... I'll lump it into malware. Regardless it has nothing to do with Media Player Classic.Originally Posted by ROF
media player classic
By maxone71 in forum Software PlayingReplies: 1Last Post: 12th Oct 2011, 07:28 -
Problem using Media Player Classic home cinema player
By True Colors in forum Newbie / General discussionsReplies: 7Last Post: 18th Apr 2010, 07:30 -
Streaming FLV in WM Player or Media Player Classic
By jlz901 in forum Video Streaming DownloadingReplies: 0Last Post: 21st Mar 2010, 11:09 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49 -
Media Player Classic and Windows Media Player 9.0
By siluet in forum Software PlayingReplies: 0Last Post: 26th Dec 2007, 10:01
