Dear all,
Sherlock Codec Detective tells me:
Warning, the following codecs were found broken:
Audio codecs:
1. Pinnacle MP3 encoder
2. WMA Pro over S / PDIF DMO
Video codecs:
1. DivX decoder filter
But it doesn't tell me how to fix them - any ideas? I don't know how a codec becomes broken but this report is different to one a few days ago in which only the Pinnacle MP3 encoder was reported as broken. Anyway the problem is that suddenly in the last few days I am getting a popping / crackling sound in the audio of some of my MOV movies. So I don't know whether the new broken codecs are the cause of this problem.
You could try re-installing them. If you have the individual codecs just remove them and re-install them. Open device manager and go to sound video & game controllers and then to "video codecs" then click on the properties tab. You can remove them from there. Not sure about the windows media codec though. You may have to uninstall & reinstall the whole program for that one. I've never had to go through that myself so maybe somebody else that's been through it can be of more help to you.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
You can also use Codec Sniper.
If they aren't needed, then just remove/delete them. Any codecs that are still needed, just reinstall.Google is your Friend -
Yes but my question is how to install them, from where do I get them? I have googled without success.Originally Posted by Krispy Kritter
Broken or not broken hard drive?
By romanstopme in forum ComputerReplies: 3Last Post: 17th Sep 2009, 13:04 -
Broken Codecs
By jdubbsmoney in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2009, 21:05 -
Programs crash because of broken codecs
By Stiff in forum Software PlayingReplies: 4Last Post: 26th Jan 2009, 16:22 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 15:29 -
How can i remove/fix some broken codecs?
By GangstaRap in forum Newbie / General discussionsReplies: 23Last Post: 23rd Feb 2008, 05:04
