I have some home movies on MiniDV tapes in 29.97 NTSC format. I have been converting them to NTSC VCDs without problems. However, now I am trying to convert these to PAL VCDs. I have the following tools available:
- Adobe Premeire (which I use to edit my videos)
- TmpgEnc
- NERO and VideoPack to Author/Burn.
I have a few questions:
1. I usually edit the video in Premiere, and create a NTSC avi file, which I then encode in tmpgenc to create NTSC VCD. If I am creating a PAL VCD, can I use the same NTSC avi file and just specify NTSC in tmpgenc settings? Or do I need to make a new avi file altogether from Premiere with PAL settings?
2. Is there a way to properly test this PAL VCD on a computer, since I do not have PAL playback equipment - I only have a NTSC TV and DVD/VCD player?
3. Does anyone have any suggestions on the settings I need to use or steps I need to follow to make sure I get a good quality output?
Check http://www.geocities.com/kristereriksson87/pal2ntsc.zip
Try the files to convert....i know the filename i pal2ntsc but it is ntsc2pal.......whn you press the link use "save target as" or otherwise you will only come to geocities......
<font size=-1>[ This Message was edited by: burro_master3 on 2001-12-26 02:32:43 ]</font> -
go here...
https://www.videohelp.com/phpBB/search.php?id=3
enter PAL or NTSC and search. there are very extensive threads detailing the problems of converting between NTSC and PAL on the forum already.
peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 17:59 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 02:22 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
