    Sep 2005
    Norway
    Hi,
    I'm a newbie so please bear with me. I love VideoHelp, there are guides for everything here. Probably one for what I need but I'm not exactly sure what to search for. On to my question:
    I am giving a presentation in class and I have a dvd that is a perfect example of what I'm talking about. In the classroom I have two options of showing this, 1) a tiny tv or 2) a computer hooked up to a projector. Unfortunately the computer does not have a dvd player and no special codecs installed and I don't think it would be a good idea to mess with school equpment, so for that reason I was hoping someone could explain to me or point me in the direction of a guide that will tell me how to take about minuts worth of consecutive video of a dvd I own and convert it to a general format so that I can burn it to a cd and run it on the computer to show on the projector in class. (btw I belive the machine is running win 2k, though some of them are running xp, if that matters?)
    Sorry for the long question and thx in advance.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    mpg 1 (and WMV) is the only codecs supported by "out-of-the-box" Windows.
    Rip the DVD as one VOB. Load VOB in VirtualDubMod. Set start and end markers where you want them. Frameserve to TMPGEnc and encode to mpg1 @ a good bitrate (like 4-5000 kbps) @ full DVD resolution
    Should be playable with Windows Media Player no prob.
    /Mats
    Feb 2004
    Australia
    Here :
    https://www.videohelp.com/forum/viewtopic.php?t=270071
    Just leave the bbmpeg settings alone , but follow the rest of this guide .
    My way involves freeware , simple and easy .
    Sep 2005
    Norway
    Awesome. That worked like a charm. thx guys.
