I have only owned one DVD recorder (a LiteOn) before this JVC. I just got it and am learning how to use it. When I use the timer programming on the JVC I notice that although I may have the time set to begin at 9:00 AM and go off at 11:00 AM the machine does not restrict what mode I can use. By that I mean I can select XP (1 hour mode) even though I have set it to record for 2 hours.
My question - which category does the machine use first? Will it record for 2 hours since that is what I set the time for or will it just record 1 hour since it is set to XP mode?
The LiteOn that I had would not allow you to set a mode that did not match your time settings.
Thanks in advance.
Thanks pepegot1.
I will look into FR mode. Can I still edit the recorded dvd on the computer, i.e. take out commercials and add menus using FR?
Thanks again.
Question About TIVO DVR Timer Programming
By Frank-0-Video in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2012, 11:39 -
i have this mp4 and i was just wondering....
By tryvora in forum Video ConversionReplies: 2Last Post: 30th Jan 2009, 23:04 -
Programming Software?
By thawizanator in forum ProgrammingReplies: 2Last Post: 11th Dec 2008, 16:46 -
Programming in C...where to get PICO or use on PC?
By Rudyard in forum ComputerReplies: 13Last Post: 14th Mar 2008, 08:29 -
programming?
By php111 in forum ProgrammingReplies: 6Last Post: 7th Aug 2007, 08:52
