Is it possible to only output the sd2.mpg file without having svcd2dvd create the dvd ?
Because i have an xbox360 with media center pc, i would like to be able to do that. The 360 only plays wmv's or mpeg's. What i do now is :
-- convert divx/avi to dvd with svcd2dvd
-- Delete the created dvd and use the sd2.mpg file for the 360
Is it possible to skip the dvd creation process and have svcd2dvd stop when the sd2.mpg file(s) are finished ?
Thanks !
No but you can click the abort button.... Are you saying that the 360 doesn't play DVDs?
Thx for the quick reply !
I can click the abort button when i am monitoring it, but it would be nice if it could stop be itself
The 360 can play dvd's, but i have all "internet" movies on my mediacenter pc so it can stream it around the house to a 360.
The 360 can stream pics/music/video, video only when you have a window media center 2005 o.s. And to complicate things further ; only mpeg and wmv..
Guess MS wants you to buy a media center pc/o.s. to stream video.
I found that most other divx-mpeg converters give worse image quality then svcd2dvd, so have to do this "workaround".
Keep up the good work, great program! (and when you have time, please consider an sd2.mpg output only "button" on your next release) -
Well for the time being:
Should do the job for you. It will process all assets to S2D mpegs. (as far as i remember...)SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
mpg dvd file?
By just in forum Newbie / General discussionsReplies: 7Last Post: 20th Nov 2008, 21:32 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
Burn MPG file onto DVD
By geek2330 in forum Newbie / General discussionsReplies: 15Last Post: 2nd Oct 2007, 08:51 -
mpg to dvd keep file size
By bladerunnerx_x in forum Newbie / General discussionsReplies: 10Last Post: 9th Sep 2007, 13:12 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
