  1. HELP! vcd will skip tracks after burning.
    When I burn to vcd format & play in my DVD player, most of the time it will skip tracks.
    It will play like tracks 1,2,3,4,5 then skip to the last track.
    I have tried burning all files into MPEG vcd NTSC format first and it still does the same thing.
    What could be the problem?
    I am using Roxio Platinum 5.
    Dec 2001
    In front of the keyboard!
    Try another burning program..
    I swear by NERO... Never had that problem.
    Does the MPEG you make play well on you PC?
