Looking to see what CCE Basic can do.
Downloaded trial version and did a few captures off VCR
in ADVC 100...Went well.
Now want to encode the avi file into mpg, can't find anyway to do so.
Is this because I do not have Adobe Premiere loaded ??
That little baby ain't cheap.
So is there a diferent way out, or do I have to buy Adobe ??
I did come from TMPGEncPlus, but I heard that CCE was much faster in encoding avi to mpg.
Frameserve the .avi using VirtualDub/VirtualDubMOD/VirtualDubMPEG2, or AviSynth into CCE..And if any audio conversion is needed, extract the audio streams with VDub, then try BeSweet w/ the BeLight frontend, or any of the other popular audio converters.
[hint - check the "Convert" guides to the left for further clarification
Thanks for the reply..
Got my programs mixed up..
Too many hours testing diferent programs..
Just let this die......... -
You do not need to frame serve in order to convert avi to mpeg with CCE Basic. Once you open CCE Basic just right click and add the avi video you want to convert. Once the video has been added just double click on the video file and it will open up the options window where you can set various encoding parameters. If you do not have a need to convert the audio to some other format then just leave the video/audio muxed.
The audio is nicely locked in sync with the ADVC-100 so leave it that way if possible.
The key to understanding how to run CCE Basic is to think simplistic. Right clicks and left clicks will get you pretty much anything you will need to do.bits
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 12:32 -
GOP questions in Cinema Craft Basic v2.7
By schrakapouet in forum Video ConversionReplies: 3Last Post: 22nd Aug 2008, 14:54 -
NEW VERSION: Cinema Craft Encoder SP2 1.00.01.01
By devilcoelhodog in forum Latest Video NewsReplies: 10Last Post: 18th May 2008, 12:46 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 17:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 19:05
